Old 05-09-2011, 08:49 PM   #1
opus's Avatar
Chassis: All-American R/E
8 way lights
Where are the front and rear lights connected together, on a Blue Bird? I found where the power comes from and I can manually make them work but I cant figure how to split front from rears.
Old 05-10-2011, 10:22 AM   #2
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Re: 8 way lights
I found that mine were spliced together in the port wiring channel up over the windows, so one wire leaves the wiring nest at the switches, and runs up the channel behind the driver's window -and then- the lines come together.
Hex is offline   Reply With Quote
Old 05-10-2011, 10:26 AM   #3
Chassis: Tc2000
Engine: 5.9 Cummings turbo diesel
Re: 8 way lights
Mine was wired the same way.
Great nations rise and fall. The people go from bondage to spiritual truth, to great courage, to liberty, to abundance, to selfishness, to complacency, to apathy, to dependence, and back again to bondage.
kc_4_jc is offline   Reply With Quote
Old 05-10-2011, 10:57 AM   #4
opus's Avatar
Re: 8 way lights
Ok, so thats where they are. How do I get to them easily? What must I remove?
Old 05-10-2011, 01:06 PM   #5
Hex
Hex's Avatar
Rated Cap: 42
Re: 8 way lights
There were a number of screws above the windows and at the 'base' of the ceiling panels that hold the covers for the wiring channel. If I recall correctly, the splices were mostly over the first port passenger window, though there might have been one for the front over the port driver's window.
All I had to do was remove the screws all around the panel that's covering the channel and sort of slide it down.
WARNING: Wear gloves when you try to pull these down. The top sort of has a friction 'clip' aspect to hold it to the ceiling panels and it seems to come loose all of a sudden. And if it's a big panel, it can get moving quickly, and those corners and edges can be damned sharp!
LED LIGHTS CAMO-MONSTER Alternative Fuels | Electric, Propane, Wood & Biofuels 10 03-06-2013 05:41 AM
where to buy lights Soundman1 Conversion General Discussions 3 08-14-2012 11:37 PM
Running Lights and tail lights not working bapos Alternative Fuels | Electric, Propane, Wood & Biofuels 2 12-14-2011 11:32 AM
Tail lights,running lights not working putterspitt Conversion General Discussions 2 10-12-2010 05:19 PM
Let there be lights!!! jkindt Conversion General Discussions 1 03-31-2010 08:26 AM
