05-23-2016, 11:01 AM
94 or newer with DT466?
After quite a bit of reading i am settled on a 94 or newer bus with the aDT466 and with luck a Allison 545 tranny. I was thinking 94 or newer so the rear brakes will be auto adjusters. I am wondering what i should be for year wise.
Weren't there DT466'S in buses until 97 and then totally DT466E. No E for me!
What rear gears did they come with? I want to be able to do Yellowstone coming from the midwest. I don't need major speed on hwys or Mts.
I have read a bit about the rear ratios in some threads
Thanks for looking
05-23-2016, 11:06 AM
Love the 466...hate the 545.
05-23-2016, 11:51 AM
Thanks for looking
My 92 has auto slack adjusters.
The 545 would be my last choice. Especially for mountainous regions.
05-23-2016, 12:11 PM
Rated Cap: 44 or 66? 11 rows
As I understand it the 545 won't provide much in the way of deceleration going down a hill, so it's all brakes. I would prefer a different transmission...
05-23-2016, 12:44 PM
Chassis: International 1753
Engine: 6.9 International
I'd be surprised if you found a 545 behind a dt466. Even in there lowest torque rating they're still too powerful for the 545. I'd Shoot for a 4.80 or there abouts for a rear gear. That will give you decent highway speed and quick enough acceleration too.
05-23-2016, 12:53 PM
Originally Posted by Booyah45828
I'd be surprised if you found a 545 behind a dt466. Even in there torque rating they're still too powerful for the 545. I'd Shoot for a 4.80 or there abouts for a rear gear. That will give you decent highway speed and quick enough acceleration too.
I've seen plenty of 466's with the 545's. Especially FL buses.
05-23-2016, 01:12 PM
Really? Huh, how 'bout that. Next time you see one let me know what torque rating it has.
The lowest I've seen was like 550 ftlbs which is a bit over the 545's capacity. I wouldn't think they would do something like that.
05-23-2016, 01:22 PM
I know I've seen em. My 195hp DT is rated at 520 ft-lbs but I think they made DT with even lower #'s.
I've been wrong before, though. Happens all the time.
05-23-2016, 02:54 PM
Excellent. I am learning. So which tranny do i want?
05-23-2016, 02:57 PM
Well lots of em came with 643's like mine. They're stout and function great. They don't have overdrive, though. Fourth gear is 1:1
They're great, though.
The newer OD units are awesome, like the 3060.
When I was bus shopping I was looking for any big, reliable engine with any transmission except a 545.
I mostly looked at 466's and 8.3's. The 466's are more common and I ended up with a 466 and 643. Great combo and simple.
05-23-2016, 03:09 PM
Going back to something the OP said, don't let yourself get hung up on slack adjusters as a fundamental buying criteria. This could be (relatively) easily upgraded so if you find the right bus otherwise don't let that sole point cause you to pass it up.
05-24-2016, 07:58 AM
What years are we looking at for the 3060?
05-24-2016, 07:59 AM
Thanks JB. I sure didn't know that.
05-24-2016, 10:44 AM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Like EC said, there are plenty of 545 behind DT466 engines. I own one and see them on the auctions all the time. Mine is a 1997 Genesis with a mechanical P-pump motor rated at 190hp. I also have a 1995 DT408 with a 545 behind it. I don't know the torque specs. I think at 210hp, you will see the 643.
05-24-2016, 11:54 AM
for flat travelling I find the 545 works great... I likely wouldnt want it if I were planning to run my bus over the rockies...
