Old 04-11-2019, 07:14 AM   #1
Chassis: Integrated CE S
A/C Ducting solutions
Hello all,
I am still in my demo/planning stages, and plan to do a roof raise. Part of my consideration on how high I go is whether or not I need to add extra room for A/C ducting. I plan to do spray foam insulation along the roof, so I can run the ducts between that and the ceiling I will build.
I plan to take this vehicle all over the US, and I hate hot weather. Dry heat > humid heat, but 60 degrees >>>>>>>> anything 80 and above. I like it cool, especially at night, so A/C will be important for me. It's going to be a shore power only build, so no need to worry about power consumption, but I would like to minimize price of A/C units.
My plan currently is to buy a mini split, mount it high in the back, and run a duct (unsure of the size, since it'll greatly impact headspace and vehicle height) along one side of the roof, between the insulation and the ceiling. Run vents from that to the ceiling, and on the other side have vents (floor or ceiling, haven't decided). I also haven't decided if those will simply allow air to flow between the walls/ceiling and insulation, or if I will duct that as well.
Heating will be done via coolant heater and heated floors, because heated floors are the greatest thing for your feet since sliced bread. However, on very cold northern nights, I can run the mini split in reverse for extra heating.
With that in mind, tell me about your ducted A/C solutions! Pictures are greatly appreciated as always!
Build thread: https://www.skoolie.net/forums/f11/bus-down-by-the-river-26371.html
inhof009 is offline   Reply With Quote
Old 04-11-2019, 06:06 PM   #2
I found someone here thought of using a drain spout pipe for ducting, it seems like it might work. I haven't found anyone who actually used one, though...
Old 04-11-2019, 09:46 PM   #3
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
I'm planning on having aluminum sheeting bent to form new ducting for my factory evaporator located at the back of the bus. It is still in the early planning stage but there will be three bends. One forming the corner between the bottom and side of the duct and two flanges on the side and bottom for mounting/stiffening. The top and other side of the duct will be the insulation on the roof and wall of the bus. The mounting flanges will be attached with rivets to the bus ribs and ceiling and wall sheet which will also be aluminum. I'll install vents where I want cold air while driving.
Ted
Old 04-12-2019, 11:20 AM   #4
Drain spout piping seems like a cost effective idea that will be durable. Tape all the joints to seal them and wrap the piping in insulation. You could also use plastic pipe (like PVC or other types).
I've seen some types of home ac that use flexible tubing and higher pressure to push more air through. I think the primary application is for retrofitting ac into existing buildings where they don't have access to run traditional duct work.
dgorila1 is offline   Reply With Quote
Old 04-12-2019, 07:53 PM   #5
I'm a little confused here. The split systems only require a thin copper tube between the outside part and the inside part, plus some small tubing for drainage of condensation. Why are you going to install ducting. you can also get systems with multiple inside parts. https://www.google.com/search?q=mini...=1555117727286
pengyou is offline   Reply With Quote
Old 04-12-2019, 08:14 PM   #6
Originally Posted by pengyou View Post
I'm a little confused here. The split systems only require a thin copper tube between the outside part and the inside part, plus some small tubing for drainage of condensation. Why are you going to install ductinghttps://www.google.com/search?q=mini+split+ac+system&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi81oSJ8cvhA hWR0J8KHSYpCkEQ_AUIBygC&biw=414&bih=656#mhpiv=15&s pf=1555117727286
I think they are talking about ducting air to places not directly in front of the AC unit.
Old 04-12-2019, 08:37 PM   #7
Some split systems have ceiling units...install multiple units and a small room can.
Old 04-13-2019, 01:52 AM   #8
Think of it as a home central air conditioning system verses a bunch of window units.
Old 04-13-2019, 05:04 PM   #9
This is the correct answer. Instead of having multiple AC units running occasionally, I can have one central one running more, and with some ducting and vents run it to the rest of the bus.
air conditioning, cooling, ducting, hvac
