Old 07-17-2009, 08:45 AM   #1
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
Re: A couple cool swamp cooler/ AC designs - on DC power
Virtually everyone here in NV has a swamp cooler, even businesses. They work fine if the humidity is very low. I had a portable cooler at Burningman a few years ago, and my 72 watts of solar at the time would not keep up. They also require a huge amount of water. If you're boondocking, forget it just from water consumption standpoint. Look at the component power draw; I suspect that a respectable solar array will operate a properly spec'd unit O.K. And if you travel anywhere where there's humidity, forget it!
The humidity in Winnemucca NV got down to 6%, Yes 6% yesterday!! Any increase in moisture helps Sooooo much! Reduces the amount of red buggers in the nose!
If it isn't grown, it has to be mined
http://weathersticker.wunderground.c...Winnemucca.gif
elkoskoolie is offline   Reply With Quote
New Here... working on my own sketches and designs bus-bro Conversion General Discussions 7 03-12-2013 11:10 AM
Cooler basket? Diesel Dan Everything Else | General Skoolie Discussions 7 11-07-2011 09:13 AM
What size tranny cooler do I need? ErrabundusBus Conversion General Discussions 1 03-07-2010 10:02 PM
Transmission cooler Russell Conversion General Discussions 2 01-27-2009 07:46 AM
Allison trans cooler hoser Everything Else | General Skoolie Discussions 2 04-26-2006 06:17 AM
