Old 07-12-2016, 07:23 PM   #1
a friend gave me a generac
Generac Propane Generator 15kw Single Phase Weather Proof Enclosure
similar to this one..... but Model # is 00754-5 Serial # 3044045
I'm running into deadends at Generac's website, looking for replacement Distributor Cap & Rotor.
Anybody have any luck finding Generac parts?
and no, it's not hot... I know the back story
Old 07-12-2016, 08:00 PM   #2
Carytowncat's Avatar
Wow injust fell down the interweb Rabbit hole of curiosity. It seems Generac makes their own engines at their plant in WI.
Good luck!
Old 07-12-2016, 08:23 PM   #3
Good luck!
I just started chasing this rabbit....
I found some info from a poster on another forum
"I work for a Generac industrial dealer and need help that Generac is unable to give... Back in the mid-late '90's they used a 1.6L Fiat engine on 10-25kW NG/LP generators. Recently I have found out that they no longer supply the distributor cap or rotor button for this engine. I have been able to source the cap but have had no luck on the rotor. It is supposed to be a Fiat P/N 71371301. I'm hoping someone has run across this before and could provide some assistance. Thanks!"
one answer:
"These engines were not released in the US for automobile applications, but they were in Canada and the UK. I have been buying my parts on eBay from a user focus212 in the UK. Prices are much less expensive than Generac even with the shipping. The Part numbers I have are Intermotor 34800 Condenser, 48212 Rotor, 45460 Cap, 22271 Points (Which he sells under part # XR240) not sure of mfg name. I've been using BPR5ES plugs Part # 7734 found locally. Hope this helps those that are still using these generators. I'm currently searching for an oil fill cap for this engine. I found a mfg in the UK for the governor throttle linkage for those having issues with that."
the rest of his answers:
Generac 1999 Fiat 1.6L engine distributor - SmokStak
Old 07-12-2016, 08:35 PM   #4
oh good Lord!
40 pages of Rotors!https://www.ptz.si/media/Katalogi/CA...ORS%202015.pdf
I can't use this thing as a boat anchor.... it's heavier than my boat!
Old 07-13-2016, 05:35 AM   #5
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Perhaps you could go at it from distributor make and number. Good chance it's a Marelli, I doubt if they used a different cap just for Generac.
Old 08-20-2018, 09:07 AM   #6
golfersmurf57's Avatar
Here's a crude thought to try. Remove the distributor- measure the diameter of the hole- find a dist with same cylinders and hole size - install your gear on it. Might be possible to get mfr. number like ducellier or prestolite on a tag on the case as well. I had same problem with a Kawasaki 3 cyl in a Cushman. Used opel points and condenser.
golfersmurf57 is offline   Reply With Quote
Old 08-20-2018, 09:20 AM   #7
joeblack5's Avatar
Year: 98
fleabay
331785280884
Seller assumes all responsibility for this listing.
good luck J
Old 08-20-2018, 01:20 PM   #8
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
try...
fiat x 1/9 late seventies early eighties.......
william
