Old 01-20-2015, 04:17 AM   #31
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by Zephod_beeblebrox2 View Post
I've replaced the front two passenger windows with aluminum paneling and replaced the remaining plexiglass window with a transplanted window.
Then... I took the bus to the store and bought some donuts.... First run in 3 weeks. It was amazing how far the wheels had sunk into the sandy soil in just 3 weeks!
Yeah I move mne every couple weeks as the sandy cow pasture I keep it in starts to give way under the tires. I suppose I should get some boards to park on.
I need to tag mine still.
Any pics of the paneling you used to replace the windows?
Old 01-20-2015, 07:13 PM   #32
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Zephod_beeblebrox2 is offline   Reply With Quote
Old 01-21-2015, 08:06 PM   #33
Year: 1994
Engine: 466dt
Rated Cap: 59
[IMG]
There - a pic with a real camera
Old 01-25-2015, 02:35 PM   #34
Year: 1994
Engine: 466dt
Rated Cap: 59
Whoever suggested furring strips was brilliant. I just bought some packs of them and they're cheaper than the 2*2 I bought before and dry nor mushy
Old 01-25-2015, 06:49 PM   #35
Year: 1994
Engine: 466dt
Rated Cap: 59
I've been working on her this weekend
Old 01-25-2015, 07:08 PM   #36
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Cool. Glad youre maintaining progress. Hows your weather been up there?
Old 01-27-2015, 05:21 AM   #37
Year: 1994
Engine: 466dt
Rated Cap: 59
Weathers been OK. Close to freezing at night but warm enough to work outside in the day without a sweater.
Old 02-22-2015, 09:30 PM   #38
Year: 1994
Engine: 466dt
Rated Cap: 59
The bath is almost fixed in place. I still need to put the outlet pipe but its almost done. The mount for the bath is done. Maybe some moving around so the hole misses chassis members.
Old 02-24-2015, 07:05 PM   #39
Year: 1994
Engine: 466dt
Rated Cap: 59
Hmm... I sealed a lot of roof leaks but it seems a couple remain.
Solution - caulk the suspect areas then go along every roof seam with aluminium tape. That stuff lasts forever and shouldn't crack. Finally, its paintable so I can happily paint over it.
The bath was a waste of time. No way could I make it fit. Aside from being too long, the limited movement I had was insufficient to allow me to move the drain out of the way of a chassis member and the low ceiling means raising it was not possible.
Old 02-24-2015, 07:07 PM   #40
Engine: 190hp 5.9 Cummins
have you tried to move the door to the middle of school bus kimberlink Conversion General Discussions 20 12-15-2017 04:12 PM
*Sold* Converted Bookmobile for sale in Middle Tennessee josetann Classifieds | Buy, Sell, Swap 14 10-20-2011 08:02 PM
Rear exit door on a full sized blue bird SCARECROW Conversion Tutorials and How-to's 1 05-29-2011 08:55 PM
