Old 02-24-2015, 07:08 PM   #41
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
I can't cut chassis members.
Zephod_beeblebrox2 is offline   Reply With Quote
Old 02-24-2015, 07:17 PM   #42
Engine: 190hp 5.9 Cummins
Are you talking about the ribs in the floor, or the bus frame?
Old 02-24-2015, 08:58 PM   #43
Year: 1994
Engine: 466dt
Rated Cap: 59
The beams supporting the floor. That's a definite no no
Old 02-25-2015, 10:08 AM   #44
That would not stop me.
I would cut what you need to, add some support back to the side of the member you cut.
My shed has three ribs that have completely failed, broken and no longer connected to the sheet metal floor. It's still more than strong enough.
Even if you just cut that one and don't add any other support, you will still be fine.
Old 02-25-2015, 10:31 AM   #45
Year: 1994
Engine: 466dt
Rated Cap: 59
The bath was in the previous peoples conversion. I decided to go with a shower instead. The shower base is $125 so its not too bad.
Old 02-25-2015, 10:42 AM   #46
Year: 1994
Engine: 466dt
Rated Cap: 59
Another thing... The bath is 30x60 and the two windows it takes up will allow only 56 inches meaning I would have to replace a window with sheet metal or have a funky wall. The shower pans are 48x32 which means I can have a cupboard hidden away beside the shower and get all the light from two windows.
Old 02-25-2015, 10:50 AM   #47
That's a good price.
I stayed with a tub in case my running water don't work for some worst case scenario. That way I can heat water on my wood / coal stove and pour it into the tub.
Old 02-25-2015, 10:53 AM   #48
Year: 1994
Engine: 466dt
Rated Cap: 59
That's a neat idea. An alternative would be to heat a bucket of water and have an old style scrub down.
Old 02-25-2015, 11:13 AM   #49
The bucket scrub is what I do now when I don't feel like going to the gym after a hard day of work.
Old 02-25-2015, 11:27 AM   #50
Year: 1994
Engine: 466dt
Rated Cap: 59
The plan is over the weekend to run wires from front to back under the top access panels for my rear view camera and my forthcoming trailer. If there's time after that, to sand the plywood floor and rivet a plate over one of the holes the hillbillies cut in the floor. I might have to replace some of the plywood. I'll also have to caulk and paint the windows on the inside. Another thing to do is to reseal the one roof leak that drips on a wheel arch. Then I'll be able to start construction of the bedroom. Now the bath isn't going to be present, I have a load more space.
have you tried to move the door to the middle of school bus kimberlink Conversion General Discussions 20 12-15-2017 04:12 PM
*Sold* Converted Bookmobile for sale in Middle Tennessee josetann Classifieds | Buy, Sell, Swap 14 10-20-2011 08:02 PM
Rear exit door on a full sized blue bird SCARECROW Conversion Tutorials and How-to's 1 05-29-2011 08:55 PM
