Old 10-04-2008, 08:01 PM   #1
Re: Access to electrical panels - electronics
access is good, check out the how to tutorials and look at boats and factory rv's, you will probably want a monitor/switch panel inside and a central power locker with the inverter,batteries,switchgear,shorepower cable, etc all in on place.
it will be to your advantage to take your time and make neat harness with enough length that you can open the monitor panel and access the back side when needed.
Old 10-04-2008, 11:43 PM   #2
I think I would us an enclosure/box hinged on the side and mount all the monitor stuff in the door and put the works inside with the harness running along the hinge and doing a u turn and coming back along the hinge to every thing inside. use the raceway with slots in the sides and a snap on cover to keep the wireing neat. then make a smoked plexiglas cover over the front panel so all you see is the indicator lights.
Old 10-05-2008, 01:03 PM   #3
GoneCamping's Avatar
I installed my RV style breaker box on the end of the kitchen counter cabinet, and have easy access to the back side of it. This box handles all the 120vac and the 12dc stuff....
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Cannot access How-To section Accordion Forum Admin | Account Help | Suggestion Box 1 02-28-2013 01:15 PM
Access Panel below tiled hearth... thommassey Conversion General Discussions 2 01-21-2013 09:04 PM
Where do you put your stereo or other electronics? stonestatue Conversion General Discussions 17 01-15-2013 05:37 AM
Vibration and electronics? GoldenGate Conversion General Discussions 12 12-10-2010 09:07 PM
How do I access all buses at once on Craiglist? greyguzziart Classifieds | Buy, Sell, Swap 2 10-06-2009 09:44 AM
