Old 10-05-2014, 10:01 PM   #1
Coachwork: Eldorado
Chassis: Areotech
Engine: Diesel
Added topic, & running drain lines
My friend who is doing a conversion is interested in using an exterior potable water hose versus pex. My comment was longevity, any other comments or words of wisdom? She'll also be traveling by herself most of the time. Does it make sense to have only one waste tank versus two? Thanks for the input.
NEW..... when plumbing drain lines under the bus, it it best just to use abs or galvanized? My concern is the exhaust line and possible rocks hitting the plastic and shattering it. Any thoughts? Thanks, greatly appreciate all input.
DaveLind is offline   Reply With Quote
Old 10-06-2014, 12:26 AM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Potable water & waste tanks
PEX will not only hold up to the mythical high water pressure (which you will find if you use potable water hose) but it will hold up to freezing better. We have blown re-enforced potable water hoses. Use what you want. If it fails then you can post here and let us all know the it wasn't a good choice.
As for a single waste tank. That's okay too if you will remember to always dump before you back up into the shower and you always keep water in the sink and shower p-traps. Upside of having a single tank is that you will never have to worry about the Tower of Doom due to the large amount of water you will be running thru the waste tank.
We have separate tanks. We bypass the grey tank while on full hookups so the grey direct drains into the sewer. Since we have installed a residential toilet, we will eventually redo the plumbing and put a diverter valve on the toilet to bypass the black tank while on full hookups.
Fulltime since 2006
Old 10-06-2014, 01:18 AM   #3
Chassis: Genesis
Remember PEX is not friends with sunlight, it's main (only?) weakness.
Timelord is offline   Reply With Quote
shower drain trap? bus-bro Conversion General Discussions 2 05-27-2013 10:04 PM
parasitic battery drain - help?!?! Redbear Conversion General Discussions 8 07-16-2012 08:15 AM
Frame rails as drain traps? bus-bro Conversion General Discussions 5 04-22-2012 10:45 AM
Cat 3208 coolant drain? paul iossi Caterpillar Drivetrain 2 11-11-2009 01:32 AM
Page 6 added.... Vern1 Skoolie Conversion Projects 5 04-22-2004 09:38 AM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
