Old 02-27-2005, 01:57 PM   #1
Adding a second floor to a bus - good idea?
I started a post to find out about the experiences others have had with grafting a VW bus to the roof or more broadly adding a second floor to their bus. Several people decided to get off on a tangent about police behavior (please start your own thread if you want to talk about something other than adding a second floor). Without going into the cop issue again, can anyone tell me about how they have added a second level to their bus or seen it done?
dphillips is offline   Reply With Quote
Old 02-27-2005, 02:02 PM   #2
This was my original post - pre cop-talk takeover
Can anyone tell me their personal experience with raising the roof of their bus? I have seen, and like the idea of, adding a VW camper bus to the top of a dog nose style school bus. I have four kids and plan to use the addition as a group sleep/play area. They like the idea of having a space of their own and the Dr. Suessian asthetic. I have found images of the "Boogie Bus" with one VW grafted into the roof in the slide out posting elsewhere on this site, and the "Magic Bus" with two zebra striped VWs on the roof. The only opinion I have found on the subject was by Mr. Sharkey (can not recall the URL) who disliked the idea beacuse of raised center of gravity, increased need for dodging trees and powerlines, squeeks, rattles, leaks, and the amount of gained space for the effort, but his objective is to gain light and head room not gain sleeping space. His complete removal of his Crown bus roof is total overkill for my objective. Is this VW bus modification worth the effort, totally stupid, or somewhere in between?
Old 04-23-2015, 08:45 PM   #3
Yeah so, me too, what gives? Has anybody done this I am into it too.
greenerbusdweller is offline   Reply With Quote
Old 04-23-2015, 08:54 PM   #4
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Holy old thread. You just resurrected a thread that was 10 years old. lol.
porkchopsandwiches is offline   Reply With Quote
Old 04-23-2015, 09:03 PM   #5
I have a 85 Vanagon I'll sell you to cut in half. I wanted to use it for my bus but I decided on doing a 20 inch roof raise instead.
AtoZ is offline   Reply With Quote
Old 04-23-2015, 09:17 PM   #6
That might be cool. But I'm wanting to know how it's done and how it works for people in general.
Old 04-24-2015, 03:50 AM   #7
It was done w/I the last year or so haven't seen an update tho'
Old 04-24-2015, 09:05 AM   #8
Engine: 190hp 5.9 Cummins
I like the idea, as long as your under 13'6 you will be fine.
I have lifted the $hit out of my bus. 23 inches roof raise, and 12 inches of lift on the coach work.
I will be hanging all my real heavy stuff down low, so center of gravity will not be a issue. Also I will just pull over in windy weather, and drop the stabilizers.
I considered mounting a glass roofed minivan up there because I love laying in bed looking at the stars. But the van would be too high with my other lift mods, so I had to let that go.
If I was you, I would start by lowering the entire bus on it's chassis. Depending on the style of bus, you would need to lift the engine so it won't drag the ground, then slam the chassis withing a few inches of the frame touching the rear axle. This will buy you anywhere from 6 inches to a foot more useable space on top.
Now using two curved roofs will just waste space. So I would drill every rivet out of the chair rail, and lift the entire body of the bus off the floor. Then using the same method as a roof raise with formed hat channel, extend the body height 4 feet.
Now the simple part. Measure down 4 feet from the peak of the roof on each side. Again using formed metal for the new second level floor joist, attach them to each side of the support ribs at the 4 foot mark. This is your new second level floor, and the new ceiling for the first level.
Now you have a nice flat, easy to finish ceiling on the first floor, and a 4 foot attic for the kids with a flat floor.
Are you really up for this much work? Most take years to complete a simple conversion. Metal work takes forever.
Old 04-24-2015, 09:25 AM   #9
lowrider bus
Old 04-24-2015, 09:47 AM   #10
I will draw a diagram when I get time later.
Is this transit bus a good idea? djDK Conversion General Discussions 33 03-22-2017 02:48 PM
cat 3116 a good idea natertots Conversion General Discussions 11 08-25-2014 01:59 PM
Adding R14 under-floor without losing interior space... baadpuppy Conversion General Discussions 5 02-20-2011 01:45 PM
Adding gasoline to diesel fuel... Not good frank-id Everything Else | General Skoolie Discussions 7 02-02-2011 06:48 AM
Party Bus- Is this a good idea? OregonFan2008 Everything Else | General Skoolie Discussions 16 02-21-2007 10:31 AM
