Old 01-08-2010, 03:10 PM   #1
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
Adding a tach to a diesel...
I'm looking to add a tach to my bus. It didn't have one from the factory and I really think I kinda need one. Are there better tachometers out there than others? I think that there are different ways to activate them too. I have seen a few in the $125 price range that strap to the alternator. I'm thinking this is the Hall Effect type? Anyone know how accurate these would be? Is there a way to determine how accurate they are? I did a search and I didn't get much except that they are different from the tach on a gasser...which I've installed two before.
Any advise is appreciated.
Thanks.
Ben.
NewSkewlHauler is offline   Reply With Quote
Old 01-09-2010, 02:59 AM   #2
Re: Adding a tach to a diesel...
I haven't tried one, so this is just the theory, which is sound:
The alternator windings put out AC, which is turned into pulsed DC by going through the diodes. It should be no problem to count the pulses and determine accurate alternator RPM. To be accurate displaying engine RPM,there would need to be a calibration built in to compensate for the speed change of engine pulley versus alternator pulley size. A tach might just be preset for an average or common pulley pair. Also, if the alternator had one or more bad diodes, the number of pulses would be off (and your battery would have trouble charging).
Old 01-09-2010, 10:35 AM   #3
Coachwork: Ward Genesis
Engine: DT466/MT643
Most older diesels (and some newer ones, I drove a 1997 that had it) used the alternator-drive tach. Newer ones run off the ECM.
Jarlaxle
Old 01-09-2010, 01:50 PM   #4
marine diesels usually use an electronic tach using the alternator for the pickup signal, the other option (expensive) is to use a transducer that picks up a signal from a crank sensor or counts the teeth on the ring gear, both are more accurate than the alternator pickup version but are really only necessary for test and development work.
I use a handheld optical tach when checking/troubleshooting for governor set points or rpms, it uses a piece of reflector tape on the crank pulley or flywheel and a handheld reader that you point at the tape to read the signal, it's handy but not permanent installation friendly.
Adding gasoline to diesel fuel... Not good frank-id Everything Else | General Skoolie Discussions 7 02-02-2011 07:48 AM
IH S1700 Tach Drive Question the_experience03 Conversion General Discussions 0 10-12-2009 02:08 PM
Adding WVO to diesel canon Veggie Oil | WVO | Biodiesel | SVO 3 05-16-2009 10:33 AM
Adding 3-4 MPG adding ounces of Acetone to your fuel, read. Gyva Everything Else | General Skoolie Discussions 2 02-27-2007 06:00 PM
Has anyone added a tach to their diesel bus? phillbus914 Conversion General Discussions 4 09-26-2005 09:27 AM
