Old 08-30-2010, 08:15 AM   #1
adding rear deck
Im thinking of adding about 2 1/2 ft rear deck of the back, to hold storage , fire wood etc, maybe my generator. whats the best way to attach it? to the bumper? or cut holes and slided to the frame, I would think it should hold about 400 pounds? any comments would be great.
still working on the bus, but we have it to the point where we have been camping!! its great.
Old 08-30-2010, 08:27 PM   #2
Year: 93
Chassis: ?
Re: adding rear deck
I added three ft. I removed the bumper and attached directly to the frame with heavy angle iron crossed braced. If I could have sourced a bus frame I would have salveged the extensions out of that. I tend to build heavy though. See Der Bus. There is a picture or two there.
swhite832 is offline   Reply With Quote
Old 08-30-2010, 11:00 PM   #3
Chassis: Ford E350
Engine: 7.3L Turbo Diesel
Rated Cap: 19
Check this link http://seanf.smugmug.com/Bus-Convers.../1329829_3ZmUN This is how I plan to do my rear deck. Perhaps its not strong enough for 400 lbs though. Hopefully it give you an idea. I also am breaking down a metal bedframe, that I got at the dump, for the angle iron.
zman18 is offline   Reply With Quote
Old 08-31-2010, 04:30 AM   #4
Year: 93
Chassis: ?
A cantilever made from bed frames for 400# rolling down the road? I hope I can talk you out of that.
It would prolly hold if it was just a shelf with four legs. Driving down the road turns a static load into a dynamic one. Every road imperfection will be amplified on the end of that cantilever. IMO a bed frame will eventually fail and it will fail while driving down the road. Im not trying to bust your balls but I would hate to see you lose even a inexpensive generator.
If you look at receiver hitch baskets notice how thick the "square tubing" is. If youre going to go cantilever, go big on the metal.
Old 08-31-2010, 10:19 PM   #5
Year: 93
Chassis: ?
Nice bead Smitty! Obviously you didnt go to Mud Dob U. like i did
S
Old 08-31-2010, 10:31 PM   #6
smity, I looked at your deck , fantastic job, You can land a chopper on that. might be a bit over kill for what i need.
I looks like nice wielding job, is it ok to wield to the frame? for some reason Im thinking that shouldnt be done
tks
Old 08-31-2010, 11:31 PM   #7
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
If I'm seeing it right, the only welding Smitty did on the frame was at the very end of it, which is perfectly alright. That won't jeopardize the structural integrity, especially with the weld spot being centered to the length of the material he used, with 4' sleeving the frame and tied in with bolts.
You're right about not welding on the frame, though. All the modern frames are tempered, and a welding heat will take it away and leave you with a weak spot or spots.
bus-ted is offline   Reply With Quote
Old 10-27-2010, 07:34 AM   #8
However, it's up to him if they wanted to weld the frame. Try to figure out what would be the best and comfortable for the deck. And then, you can make a good process to add some thing in the deck.
My seo
ZanderJay is offline   Reply With Quote
Old 10-27-2010, 04:25 PM   #9
Year: 1983
Chassis: Carpenter
Engine: 8.3
Whats the max you could push out the rear for a deck if it were built like Smitty's I have considered this addition but have been a bit leery. I have small trail bikes that could but parked up there during transport and then used as nice space away form the rug rats in the evening hours. Any advise would be appreciated.
seth
"grease buddy" and all around nice guy
madpsalmer is offline   Reply With Quote
Old 10-27-2010, 05:16 PM   #10
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Here's a deck for ya. Extended the frame back about 2 feet, reattached the bumper, added a receiver hitch, then plugged in my bike hauler.
Second vote for building with big steel, better to be overbuilt than underbuilt.
Ob1 is offline   Reply With Quote
Old 10-28-2010, 10:00 AM   #11
Year: 1983
Chassis: Carpenter
Engine: 8.3
Ya I suppose I should think about the drive-ability implications. Thank you Smitty!
seth
Old 10-28-2010, 07:02 PM   #12
thats a good point about scraping the rear deck, as it is now I find it eazy enough to hit the tail pipe backing out of my drive way. I have been rethinking this deck, at first I wanted to put the generator on It, but Im going to mount it buy the battery box. I would still like to put a small deck, just to carry fire wood, maybe gas, but it will have to be 18 to 20 inch wide, Ill pounder this for the winter, we had a bit of snow today burrrr its coming!!
Old 10-02-2016, 11:00 AM   #13
I've had the idea of adding a rear deck also, however I was considering the flatbed off a pickup. cut it in half and find something close to same gauge as bus frame. That way you have a receiver hitch at the back
pcdreams is offline   Reply With Quote
Old 10-02-2016, 02:05 PM   #14
Just plug a tailgator into your receiver hitch
Old 03-21-2019, 06:56 PM   #15
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
Anyone else contemplating a rear deck? Just thinking a year or so out when we get our little Isetta on the road. Figuring a 4' deck would be perfect to hold it. Full up, it 'only' weighs 750lbs so with some stout extensions on the frame this should work..?
Dave
Old 03-21-2019, 10:01 PM   #16
Wild_Sunshine Bus's Avatar
Chassis: BlueBird
Engine: T444E Diesel-195 HP
Rated Cap: 42
Wink
Iam going to attach these supports to the bumper using longer carriage bolts. They measure 3 1/2 feet long.
File Type: jpg F7FBEA56-6102-4160-A225-E6B4339AAABA.jpg (230.9 KB, 12 views)
Wild_Sunshine Bus is offline   Reply With Quote
Old 03-22-2019, 08:38 PM   #17
plfking's Avatar
Rated Cap: 34
I'll be building one, but only 22-24" deep to hold a dual sport dirt bike or a moped.....around 300 pounds max. I'll make supports similar to Wild Sunshine's pics, and attach using the existing bumper bolt locations. I'll also hinge the center section to swing down out of the way so I can access my "garage' from ground level.
Don
The Busted Flush
REAR DECK bansil Conversion General Discussions 4 11-19-2012 10:11 PM
how long is your rear deck? gbstewart Conversion General Discussions 1 05-26-2011 10:39 AM
Someone, somewhere wanted pics of my rear deck. crazycal Skoolie Conversion Projects 4 12-14-2008 01:05 PM
Question about a rear deck phillbus914 Conversion General Discussions 25 08-18-2008 07:37 AM
Rear Deck on Bus... aceinthehole2220 Skoolie Conversion Projects 7 07-30-2008 11:49 PM
