Old 02-10-2012, 10:33 AM   #1
Re: Adhesives for Insulation
I keep 3m 8088 spray adhesive on hand at all times for use in upholstery work for the hot rods.. It doesn't work on metal well in heat in my experience, if one is only using the adhesive as the fastener..
Old 02-11-2012, 11:56 AM   #2
browncrown's Avatar
Rated Cap: 79 at Birth
I have not used the 3M adhesive before so I don't know how well that works. I did use the Liquid Nails on my ceiling. I glued styrofoam type insulation to the ceiling and then carpet onto that. I live in an area where summe temperatues go above 100 degrees and the roof takes a lot of heat. So far, everything is holding up well and its been up there about two years now.
BC
Old 02-11-2012, 03:19 PM   #3
there is more than one strength for liquid nail now. I use the high strength stuff, and even with the regular stuff it will hold on walls and so forth. Another adhesive to consider is the gallon cans of that extremely sticky rubber contact cement... I often use that on carpet squares.. it is VERY sticky and thick when applied with a metal spaula type tool
Old 02-11-2012, 04:34 PM   #4
browncrown's Avatar
You're right on about the different strengths. I should have mentioned I used the Heavy Duty strength when I applied the ceiling areas and also used that strength on some of the paneling I put up on the walls.
BC
Old 02-12-2012, 02:45 AM   #5
They make rubber cement in gallon cans. You can get it at the carpet stores and i think the last gallon i bought was at home depot. I started using it many years ago when thin carpet with designs cut in it were put on some commercial building walls.
How much insulation did you add to your bus? TygerCub Conversion General Discussions 8 03-09-2012 03:51 PM
? Insulation???? Six Four Everything Else | General Skoolie Discussions 3 02-20-2011 07:57 PM
Insulation TygerCub Conversion General Discussions 7 08-24-2009 07:57 PM
All about insulation ollopa Conversion General Discussions 5 11-15-2006 11:26 PM
Insulation? Father_of_10 Conversion General Discussions 20 02-24-2004 11:10 AM
