Old 05-22-2018, 08:48 PM   #1
HappyInTN's Avatar
Chassis: Genesis
Rated Cap: 84lug
Advice needed: Ceiling adhesive removal
I need suggestions on how to remove the adhesive on the ceiling left behind after the removal of the insulation. I am lining my entire bus with Lizard skin (floor, ceiling, and walls) and want the adhesive gone so the sound deadener and the ceramic thermal coat both have a good surface to stick to.. suggestions.
https://youtu.be/W6XG1InN_h8
Note: I am no longer selling skoolie insurance. I sold my agency and am traveling N. America full time with my family. Wish us luck!
Serenity Bus Project: OUR NEW EBOOK. ITS A HOW-TO GUIDE. PLEASE CHECK IT OUT! --> https://www.serenitybusproject.com/store/p1/So-Your-Dream-Of-Owning-A-Skoolie.html
HappyInTN is offline   Reply With Quote
Old 05-22-2018, 09:35 PM   #2
I imagine it's dry and can be removed with an orbital sander. If it's really hard to get off and it were mine I'd lizard skin over it.
Old 05-22-2018, 11:45 PM   #3
A good stiff brush, on a medium length handle should do it.
1olfart is offline   Reply With Quote
Old 05-23-2018, 05:40 AM   #4
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Oscillating Multi-tool
https://m.harborfreight.com/power-to...not%20provided
The flat bit works great.
Nick
Old 05-23-2018, 06:22 AM   #5
Post pics please. My 92 Ward had Asphalteum under the roof. Took a LONG time to remove.
Its an asphalt that's like tar.
Old 05-23-2018, 11:19 AM   #6
HappyInTN's Avatar
Chassis: Genesis
Rated Cap: 84lug
Thanks guys.. I bought some Krud Kutter (5 gallon jug) and a bug sprayer.. I am going to spray..soak..spray..soak then pressure wash.. I thought about sand blasting but the media for a sand blaster for about 300sqft was stupid expensive after you factor shipping and equip rental. I hear you on the orbital sander but I am hoping very much that I can avoid that time vampire project if at all possible. I'll let you all know how it turns out with the Krud Kutter. Also I know many on here were really interested to see how this Lizard Liner comes out, I am too. I will post those update on my Serenity Bus thread. Thanks every contributor on the site for being such a tremendous resource
Old 05-23-2018, 12:29 PM   #7
A Kwik note regarding the old "asphateum" used on many early buses...
Be advised...it will burn.
Welding on the opposite side can easily light it off.
Go ahead...ask me how I know.
Old 05-23-2018, 02:20 PM   #8
Rovobay's Avatar
Rated Cap: 35
LMFAO
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 05-23-2018, 02:30 PM   #9
we had all of it gone by the time we went to welding. But even grinding the tar off with a grinder got it hot enough to burn me. Stuff is just NASTY.
ceiling adhesive removal, lizard skin, metal prep
