Old 01-22-2011, 06:01 AM   #1
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Re: air brake failure
yes
And thankfully so. After all, anyone behind a vehicle needs to maintain a safe distance should the vehicle ahead slow dramatically. Whether it is to keep from running over a child, a brake failure, or a sudden need for McDonalds.
Ob1 is offline   Reply With Quote
Old 01-22-2011, 06:29 AM   #2
Seeria's Avatar
I'm no pro on these brakes, never even used one. I do ride the city buses and the drivers tell me that their air brakes send off alarms like crazy and you've 15 seconds to move over to side of road before the brakes do their thing. It's slow braking not on a dime thing. Can't imagine going 50 miles an hour and it stopping on a dime.
Old 01-22-2011, 06:49 AM   #3
Engine: 466DT
But it doesn't happen like in the movies. I drive a 33000# single rear axle/with air brakes/mdt everyday for work. Out of curiosity, I have pulled the parking brake valves while traveling say 20-25 mph to see what happens. No skidding has ever occured on dry pavement. Its just like laying on the brakes pretty hard, and coming to a quick stop. Never thought I was going to fly out the windshield. Theres alot of weight that pushes through the brakes. I live in a little bit of rural Iowa, so no other vechicles were around.
Hvbuzz is offline   Reply With Quote
Old 01-22-2011, 07:59 AM   #4
Send a message via ICQ to mightybus
I pop my brakes often for instruction and entertainment. There is a proportioning valve that disallows to much air being released from the diaphragms at one time when popped and none added.
mightybus is offline   Reply With Quote
Old 01-22-2011, 08:01 AM   #5
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
You would have to loose ALL of the air all at once for that to happen. Most air systems maintain 100 to 120 psi. There should be both a warning light and a buzzer at about 60 psi. In my experience the brakes start gradually applying at 50, much below that. I have maintained enough air pressure to keep going with some pretty major air leaks, traffic is the BIG air user, when you step on the brake you dump air.
Old 01-25-2011, 09:21 AM   #6
browncrown's Avatar
Rated Cap: 79 at Birth
Federal law required the 121Brake System, more commonly known as the Dual Air System on all buses built after 1977, so that is most likely what most of you have. The Brown Crown has this type of system. It is designed to always afford rear braking capability. If it has a failure in the front half of the system, the front brakes will not work. You will get a warning light and buzzer at not less than 60 psi as has been mentioned, but the spring brake is not going to set because the shuttle valve will shut off the leaking front system and you can still stop with the rear brakes by simply pushing down on the brake pedal. The rear tanks will keep the spring brake from applying.
If the the rear system fails, the front brakes and the rear brakes will still work because there is a Spring Brake Modulating valve that releases modulated pressure when you push down on the brake pedal from the spring brake chamber, and the spring brake is held off from applying by the still working front system.
Except in a Total Failure, you can always stop these buses by using the brake pedal and therefore, you have better control to pull over and decide what to do about the problem.
I have pulled the spring brake on my Crown at 55 mph and like others said, it is not like in the movies. No skids and it takes about 250 to 300 ft to stop.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 01-26-2011, 08:43 AM   #7
Seeria's Avatar
Great info, makes me feel better about air brakes Thanks
Old 01-26-2011, 10:02 AM   #8
browncrown's Avatar
Your welcome, glad I could help.
BC
Old 02-14-2011, 05:10 PM   #9
dentedvw's Avatar
Coachwork: Thomas SafTLiner
Chassis: FE
Rated Cap: 60
I wanted to move the bus for Halloween last year, so I fired it up, and headed on down the road. Didn't check the brakes.
When I got to the end of the road, guess what happened. Yup, nothing. Pedal hard as a rock, no braking. I was too busy steering hard right into a busy intersection and trying not to hit the cars that were there, with tires smoking to reach for the parking brake.
Let me tell you, when you hit the frame of your bus on the ground at 20mph, it sends quite a shock to your dishes, pans, pots, drawers, and all kinds of stuff you never thought about before. I was pretty lucky, people made room, but not gladly.
I limped it home at about 5mph the next day, from only half a mile away.
I still haven't fixed it, got laid off, too much snow, etc. I need to figure out what happened pretty soon though.
I think it's air assisted hydraulic, and air assisted steering, because it was pretty difficult steering too.
I am hoping I can fix it myself.
dentedvw is offline   Reply With Quote
Old 02-14-2011, 06:05 PM   #10
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
I didnt originally post this thread.
Old 02-15-2011, 06:07 AM   #11
dentedvw's Avatar
Chassis: FE
Rated Cap: 60
I wonder if it was split off of another discussion.
Old 02-15-2011, 04:57 PM   #12
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
No it wasnt. Evidently the original post has been deleted for some reason.
Power steering failure auto-sales International | Navistar Drivetrain 0 06-29-2013 05:58 AM
air brake 101...or how to fix/diagnois a stuck brake issue bansil Conversion General Discussions 16 06-28-2012 02:28 PM
Email notification failure... Stuff Forum Admin | Account Help | Suggestion Box 1 08-05-2010 02:33 PM
Air Brake Help??? talk2cfs Ford Drivetrain 1 07-31-2010 07:12 PM
Blue Bird turn signal failure? Huey Everything Else | General Skoolie Discussions 2 10-08-2008 03:07 PM
