Old 07-06-2019, 10:00 PM   #21
Originally Posted by Sehnsucht View Post
Did it pass the 4 point air brake safety check during the pre-trip inspection?
The bus obviously has a intermittent problem if such a large leak was present the moment he started the bus he would have NEVER had enough air pressure to release the park brake.
It is very possible to pass the air brake test and then a mile down the road a valve stick open and cause a big pressure drop even with a perfectly good compressor.
Mekanic is offline   Reply With Quote
Old 07-06-2019, 10:57 PM   #22
Rivetboy's Avatar
Originally Posted by Mekanic View Post
WOW. “Emergency failure mode” ??!
I never heard that term before.
You know it sounds like his brakes work just fine. (Sounds like safety features built into modern air brake work as well) His problem is intermittent air supply.
It seems he has a quite large air leak one moment . And no leak (or one much smaller) the next.
That sounds like a prime candidate for sticking dryer valve. At least that is where I start looking.
Commas are your freind, his brakes went in to emergency, failure mode (air pressure)
Rivetboy is offline   Reply With Quote
Old 07-06-2019, 10:59 PM   #23
Rivetboy's Avatar
Loss of air pressure = emergency application
Old 07-07-2019, 04:11 PM   #24
Coachwork: Chevy
Chassis: C60
Engine: 8.2 diesel "Fuel Pincher"
Rated Cap: GVWR 27000
I think that's what it was too. The pressure remained good for the remainder of the trip. I'm going to service the drier, and the governor and of course check for any other leaks.
meyermobile is offline   Reply With Quote
Old 07-07-2019, 06:15 PM   #25
Coachwork: In the market
Which is why I asked the question. I am aware however that too many people drive these like it's their car where they just hop in and go without taking the time to properly pre-trip the vehicle but I wanted to give the OP the benefit of the doubt. It's not an intermittent problem if it occurs more than once but is ignored - that's a recurring symptom of a problem that's probably going to leave you stranded sooner or later because you chose to ignore it.
Sehnsucht is offline   Reply With Quote
