Old 02-23-2019, 12:38 PM   #1
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Air brake not releasing
The Bus has been parked for about 7-10 days. Yesterday I removed the harness for the lights and sensors for emergency exists.
Now the air brakes wont release. No alarms sound. Just the brakes wont release. Both tanks are at 120psi and I can hear the air cycling through as I press on the pedal. The pressure release valve also releases normally.
While it’s possible that the airbrake release switch is connected to the emergency exit circuit, I don’t know this for sure.
The bus is a 2007 IC CE.
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
Old 02-23-2019, 12:45 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Has to be one of the exit sensors.
I always disconnected one and started the engine.
That way I knew exactly which one.
Maybe start with jumper wires to figure out which one?
Jolly Roger bus 223 is online now   Reply With Quote
Old 02-23-2019, 01:03 PM   #3
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Hooked the harness back up. Indeed it was the emergency exit sensors. Now to remove them.
Old 02-23-2019, 01:07 PM   #4
Year: 86
Chassis: Ford B700
Engine: 8.2
Maybe just a jumper wire in the control panel to prove it closed?
Old 02-23-2019, 01:09 PM   #5
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Probably. Installing a hitch receiver today. So when that’s done I’ll track down the circuit. Determine if it’s an open or close circuit and fix it. Fairly easy to determine if the switch is open or closed when static or activated.
Old 02-23-2019, 02:54 PM   #6
Coachwork: Ic ce Navistar international
Chassis: Ce 300 school bus
Engine: 7.6L international ic ce 300 school bus
Yes there is a safety connection to back doors drops brakes from releasing it thinks does are open
Sp6saz is offline   Reply With Quote
Old 02-23-2019, 05:09 PM   #7
I'm surprised there isn't an audible warning that a door is "open". Surprising also that yours allows you to start the engine with an "open" door. Mine are all connected to the starter, open door, no turning the motor.
Old 02-23-2019, 05:11 PM   #8
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
I have the audible warning on the doors. I thought I had it on the emergency exits.
