Old 08-26-2017, 03:32 PM   #1
Clayton's Avatar
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
Air Brake question. Does anyone know much about this type of slack adjuster?
I am doing a rear axle seal and need to remove the brake drum. To do that I need to back out the slack adjuster. The one on my bus must be a really old type as I never seen this kind before. Has anyone used this type? I assume the clip thing is the lock-nut and the adjustment screw is on the back side, but I wanted to get some advice from someone who has done these before. See photo Thnx! Clayton
Clayton is offline   Reply With Quote
Old 08-26-2017, 03:37 PM   #2
LPST's Avatar
Coachwork: Eldorado National
Chassis: ESCORT RE
Engine: Cummins B5.9
Rated Cap: 32
You are correct, back it off with the adj on the back side the bracket just keeps it in place for adjusting, the new versions don't have the brackets
Trust in the Lord with all thine heart; and lean not unto thine own understanding. Proverbs 3:5
In all thy ways acknowledge him, and he shall direct thy paths. Proverbs 3:6
LPST is offline   Reply With Quote
Old 08-26-2017, 03:45 PM   #3
LPST's Avatar
Chassis: ESCORT RE
Rated Cap: 32
Ok, I had to double check in my shop ( I was second-guessing myself after I put in my reply) that is a Haldex unit, the nut on the back side is a 7/16 inch and that is the adjuster
Old 08-26-2017, 04:39 PM   #4
Clayton's Avatar
I appreciate your help. After you mentioned Haldex, I was able to find this fantastic video on them if anyone else needs it.
Old 08-26-2017, 07:54 PM   #5
I don't have air brakes but that was an excellent find...thanks for sharing.
Old 08-26-2017, 11:28 PM   #6
Skoolydoo's Avatar
Rated Cap: 2+1
Thanks for sharing
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
Skoolydoo is offline   Reply With Quote
