Old 06-20-2007, 12:36 PM   #1
CVanDamme's Avatar
Air Conditioner Amperage Draw
We have a 3000watt, 2500watt continuous inverter, will it fire up and run a 13,500btu roof top air conditioner?
Bonus question, If it don't work how do we get the smoke back in the inverter?
Thanks
Chris Van Damme
92 Blue Bird TC2000FE
The Slab Cab'n
Follow my build up here http://www.skoolie.net/gallery/v/Skoolies/Slab_Cabn
Or join the facebook group Friends of the Slab Cab'n http://www.facebook.com/group.php?gi...2145574&ref=ts
CVanDamme is offline   Reply With Quote
Old 06-20-2007, 12:54 PM   #2
Steve's Avatar
Re: Air Conditioner Amperage Draw
It could probably run the AC but might not be able to take the initial starting of the motor.
The worst that would happen if you did try it is that it would trip the breaker on the inverter.
Old 06-20-2007, 09:32 PM   #3
GoneCamping's Avatar
In theory it should work. The 13.5k btu roof top air is rated for 20 amps, but actually uses about 18 amps. At 115vac that adds up to 2070 watts.... If you try this, you would want an inverter that has room to spare, stick with 3000W peak load and at least 2000W continuous....
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 06-20-2007, 09:43 PM   #4
the_experience03's Avatar
I'm a little curious where the 150 amps of DC current to operate that thing is going to come from....
Old 06-26-2007, 07:36 AM   #5
read this, has some real-world numbers (although it IS a sales site)
1/2 way down the page where it says "Running Your Sprinter's 110V Roof A/C"
http://www.sportsmobile.com/2_sr_heatingcooling.html
Also I've read of a 'soft-start' modification for the a/c units, but don't have any links handy. You may want to google around some.
waywardfool is offline   Reply With Quote
Old 06-26-2007, 04:17 PM   #6
eggman's Avatar
My 2002 carrier 13,500 btu AC unit has 12.8 amps draw on the label. However, when I check it with an amp meter, its drawing 13.2. Even my older Dometic AC unit only draws 15.8 amps when running. I dont know what it draws upon start up, but the label on the carrier unit calls for a LRA rating of 60 amps.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 06-26-2007, 05:34 PM   #7
Steve's Avatar
The problem with using a unit that is close to your max power is that there will be huge current spike when the unit turns on so you will need to make sure your inverter has power to spare to start it up.
Old 06-30-2007, 10:27 AM   #8
Thanks
silly man, everyone knows that once the magic smoke gets out, the unit is no good!
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 07-06-2007, 07:44 AM   #9
Did you ever get it working?
QuagmireMan is offline   Reply With Quote
What amp draw ok on common? GameRV Alternative Fuels | Electric, Propane, Wood Gasification, etc. 29 05-13-2011 06:42 PM
12V bulbs and current draw. jkindt Electrical, Charging and Solar 2 02-27-2010 05:42 PM
Discovery's Mythbusters draw the Mona Lisa in 80 Nanoseconds Steve Everything Else | General Skoolie Discussions 2 08-29-2008 06:09 PM
Anybody need a $50 air conditioner? boojiewoojie Conversion General Discussions 5 03-14-2007 10:50 AM
Do Skoolie Drivers Draw more attn from Police? dphillips Conversion General Discussions 5 02-28-2005 02:21 PM
