Old 08-28-2007, 09:08 PM   #1
Air Conditioning
I am not talking about opening the door and all the windows, but an air conditioner that can be used in the rain.
For a bus this size http://i8.ebayimg.com/01/i/000/b2/55/4a43_3.JPG is a 13,500 BTU AC unit over kill?
U-Haul is offline   Reply With Quote
Old 08-29-2007, 05:39 PM   #2
Engine: 7.3 diesel
Re: Air Conditioning
I wouldn't call it over kill but you can get by with a slitghly smaller one for that size bus. But with the bigger A/C it will cool down faster. I have a 13500 on mine and my bus is a little bit bigger than one of those cut away vans. If it were me I would go with a 13500 cause it will cool better. Mine also will cool the inside down to 70 to 74 when it is 90+ outside while going down the road. On the down side a honda eu2000i will not run the thing much more than one minute . I use a larger noisy coleman 6250 to run it going down the road. Next spring I might get a second honda and connect two together then I could run it on 2 hondas.
Old 09-01-2007, 12:55 AM   #3
KC10Chief's Avatar
Rated Cap: 60
Ooh! I want a little bus like that! I would go ahead and use the 13,500 BTU AC. IT will cool down in a hurry. I use two Honda EU2000i's to run my old 13,500 BTU AC. One of them will run it for a little bit, but will eventually kick off. Where did you find that little bus? I want to get one after I'm done converting my big bus!
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
https://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 10-03-2007, 07:49 PM   #4
DizzyIzzy's Avatar
Chassis: Chevorlet AT545 Allison auto
Engine: 8.2 litter Detriot Deisel
Send a message via AIM to DizzyIzzy Send a message via MSN to DizzyIzzy Send a message via Yahoo to DizzyIzzy
That little bus is way cool. I been looking to get 4-5 of them and convert my fleet to them instead of using conversion vans. They would make awesome Ice Cream Truck!
"Escapin' through the lily fields
I came across an empty space
It trembled and exploded
Left a bus stop in its place
The bus came by and I got on
That's when it all began
There was cowboy Neal
At the wheel
Of a bus to never-ever land"
DizzyIzzy is offline   Reply With Quote
Old 12-30-2007, 04:49 PM   #5
Well I found the bus on Ebay, I really wanted to get it, but there were too many people with a zero score bidding. The seller just sold it to a Minnesotan instead and since then I have not found the right bus under $1000.
viewtopic.php?f=11&t=2404&p=21460#p21460
Happy New Year
how to add bus air conditioning? Excalibrate Heating, Cooling and Appliances 11 11-20-2020 07:54 AM
AIr Conditioning What should I use? getballooned Conversion General Discussions 3 05-12-2013 11:12 AM
Air Conditioning & Heating sportyrick Conversion General Discussions 2 06-11-2010 12:24 PM
Air Conditioning swhite832 Conversion General Discussions 8 02-23-2010 09:05 PM
air conditioning trainride Conversion General Discussions 4 08-28-2009 09:50 AM
