Old 05-13-2019, 10:14 AM   #1
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Air Dryer making unusual noise
So, my air dryer is a CR Brakemaster Model 62. It is making some rough noises as it gets closer to 120 psi. I also noticed it trying to do a little purging before 120 paint but then it builds and purges. I'm thinking that it may be time to replace this air dryer? I'm assuming it's as old as the bus (29 years old).
I haven't found much info on this item and believe that SKF now makes the replacement. I guess the real question is: do I try to figure out what is causing the is sound on the dryer and replace several hard to find parts OR do I just try to get a new replacement and put it on. Thoughts l, comments, and opinions are appreciated.
Nick
Old 05-13-2019, 10:15 AM   #2
Ninjakitty's Avatar
Pics of the partIMG_20190510_120911.jpegIMG_20190510_120844.jpegIMG_20190510_120830.jpeg
Nick
Old 05-15-2019, 03:57 AM   #3
Marceps's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
You could try replacing the filter first.
Marceps is offline   Reply With Quote
Old 05-15-2019, 06:29 AM   #4
this is one i havent seen... most of the older busses had the Haldex or the Bendix AD-4.. definitely replace the cartridge first...
Old 05-15-2019, 08:52 AM   #5
Ninjakitty's Avatar
I found this
http://waterstorage.tpub.com/T...css...6-24-4_242.htm
Which says it has a permanent filter? (Picture added in case link doesn't work)Screenshot_20190515-085203.jpeg
Nick
Old 05-15-2019, 08:55 AM   #6
Ninjakitty's Avatar
Screen shots of what I found in case link won't openScreenshot_20190515-085439.jpegScreenshot_20190515-085444.jpegScreenshot_20190515-085501.jpeg
Nick
Old 05-15-2019, 08:57 AM   #7
Ninjakitty's Avatar
Just wonder if a almost 30 year old dryer needs replacing? I'll look for a filter to replace it. I contacted SKF, who makes air dryers. I believe they took over for the company that originally made this dryer. Waiting on a reply
Nick
