Old 11-02-2010, 11:59 AM   #1
lornaschinske's Avatar
Rated Cap: 89
Re: Air Horns for Bus
I know that you can buy them from places like JC Whitney and many of them come with their own little air compressor. It's a self contained unit. David was going to get one of them for the Eagle and didn't want to tie it into the coach's air system (crappy, wimpy horn) but we scrapped the Eagle. The BlueBird has a good horn, so I don't know if we will keep it or replace at some point down the road.
http://www.jcwhitney.com/jcwhitney/t...estid=16103798
Fulltime since 2006
Old 11-02-2010, 06:26 PM   #2
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Thats the advantage of having an air system in the bus. You can hook up air horns and such without having to buy the compressor. I would think all you would need is the horns and a switch.
BUSBOZO is offline   Reply With Quote
Old 11-02-2010, 09:14 PM   #3
bus-bro's Avatar
Engine: 3208 na boat anchor
Or a valve on a pull cord.
Old 11-03-2010, 03:27 PM   #4
Rated Cap: 89
For the Eagle we had originally planned to "T" into the air bag system. We decided not to because we didn't want to risk a leak and have a "flat bag"! The air brake system was not even considered because we understood that if the air system was low, the air brakes applied. We also have air brakes on the Blue Bird. We would opt for a stand alone horn system.
Fulltime since 2006
Old 11-06-2010, 10:12 PM   #5
sportyrick's Avatar
Chassis: F33695
Engine: 427 chevy
I have had a 150dbl three trumpet horn just like you have shown for years and love it. We have never had a problem with air depletion and we have air brakes. Why wouldn't you pipe it in with your air brakes? Your air brake system has tons of cubic feet of air and a little use by the horn will never be noticed. My wipers are also air operated. I also installed a switch so I can use my regular horn or air horn or turn them both off so the kids won't blow our ears out by leaning on the horn when not wanted. Just tie into your main air system tank close to where your compressor ties in and not your brake system which is down stream from your main system. sportyrick
Old 11-08-2010, 11:21 AM   #6
Rated Cap: 89
Originally Posted by Iceni John
... Have it on the left side, then you can still be braking at the same time...
Yep... you need to be able to blast the morons while hitting the brakes because they think you can stop on a dime!
Fulltime since 2006
i dicators, wipers, fans and horns Zephod_beeblebrox2 Conversion General Discussions 0 11-03-2014 10:26 AM
Air Horns jkindt Conversion General Discussions 5 04-01-2010 09:40 PM
WANTED: Air Horns Wheelchairdude94 Classifieds | Buy, Sell, Swap 0 06-06-2009 09:59 AM
