Old 10-12-2018, 11:26 AM   #1
Year: 2006
Chassis: International IC RE300
Engine: International 7.6L diesel
Rated Cap: 33,000
Air leak maybe ?
I was under the bus and hear small amount of air hissing from this here part which Iíll post picture of ... anyone know whatís up with that?
File Type: jpg 00F28ECA-32C1-42B3-A727-296EA5E57883.jpg (169.3 KB, 7 views)
File Type: jpg 83F19E0F-3C4E-47B2-BC35-2B7AEA2B7340.jpg (227.4 KB, 6 views)
Saucenbach is offline   Reply With Quote
Old 10-12-2018, 12:15 PM   #2
Chassis: International FE
Rated Cap: 84 passengers
That is your air dryer. You could have a leaking purge valve or check your air line connections to and from the dryer.
rensch26 is offline   Reply With Quote
Old 10-13-2018, 12:17 AM   #3
Year: 2006
Rated Cap: 33,000
It’s coming from the ring around that main part I posted .
Old 10-13-2018, 12:18 AM   #4
Year: 2006
Rated Cap: 33,000
Leaking right where it looks like the bottom piece isn’t flush with the top anymore
Old 10-13-2018, 04:03 PM   #5
To my knowledge the dryer should not leak air from anywhere but the purge valve when it expels moisture. The leak is going to make your air compressor on your engine cycle more often. I'm not familiar with that air dryer model so you should try to find a model number or part number on it somewhere and find some literature for it on the internet.
air brake, air leak, air tank, bus advice
