Old 12-18-2018, 12:52 PM   #1
Chassis: TC/2000
Engine: 5.9l Cummins
Rated Cap: 72 - 27800
Air leak - these things
Fired up my bus for the first time in almost a year. Brakes pumped right up but the buzzer never turned off. Then I notice my power door doesn’t has enough pressure to shut (opens fine tho), I walk outside the bus and I can here an air leak coming from the electrical panel box and chased it down thesePictured)
Hoping someone can tell me what these are and why they’re leaking
Enrico Carini is offline   Reply With Quote
Old 12-18-2018, 01:02 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
It looks like the air solenoid that controlled my stop paddle. Trace it back and see what it's connected to if you can. My bus was equipped with to stop paddles and had two of those are electric solenoids. Somewhere on mine was an adjustment screw that I was able to turn down so no air would leak out at all.
Old 12-18-2018, 08:39 PM   #3
Chassis: TC/2000
They connect to the power door. Not sure how it could be a solenoid without any wires?
Old 12-19-2018, 06:07 AM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Just guessing here, looks to be some kind of adjustable valve. Probably to control door opening and closing speed? If that is what it is you should be able to disassemble and clean.
Old 12-19-2018, 10:19 AM   #5
Chassis: International 1753
Engine: 6.9 International
Those look like filtered exhaust ports. Trace the hoses and see where they end up. You might have the seals shot in the door cylinder which is causing the air pressure to leak through it.
