Old 07-31-2009, 07:33 AM   #1
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
Air ride question...
My Thomas has air bags on all four corners... I was wondering if these bags compensate for an uneven load? I mean if I were to load all the weight (not overloaded) down the length of the drivers side of the bus would it lean or do the bags make up for it? Just curious to what you guys think...
ezbme is offline   Reply With Quote
Old 07-31-2009, 08:13 AM   #2
the_experience03's Avatar
Re: Air ride question...
How many ride height valves do you have? Just one on each axle means that it only compensates front to back. A ride height valve at each corner or sometimes two in the back and only one in front means that it should compensate side to side.
Old 07-31-2009, 08:17 AM   #3
ezbme's Avatar
My mechanic said that there are 2 bags on each corner in the front & singles on each corner in the rear but not sure how many valves there are... Does that help?
Old 07-31-2009, 12:06 PM   #4
you have to crawl onder the bus and look for valves follow the airlines from the bags backwards towards the air source, the valves will have mechnical linkages running between the valve and the axle/suspension, the front may also be hooked into a solinoid valve that dumps the front bags to let the bus kneel for loading when the doors are open.
Air Ride anyone? Docsgsxr Conversion Tutorials and How-to's 22 01-19-2015 05:13 AM
air ride seats Newfiedogs Skoolie Conversion Projects 2 12-14-2011 03:07 PM
VERY BOUNCY RIDE ,HELP ! shortstuff Short-Bus Conversion Projects 8 10-11-2009 06:08 PM
Air ride suspension reprobate Conversion General Discussions 1 05-07-2009 07:36 AM
Out for a ride frank-id Everything Else | General Skoolie Discussions 6 11-28-2006 03:14 AM
