Old 10-24-2013, 11:58 PM   #1
xJP
Year: 1994
Engine: International
Send a message via MSN to xJP
Airbrakes Discussion
hey! I know there's a thread about how to check airbrakes...
I just have some quick questions, perhaps skill testing...!
so, I found this bus and I am extremely on the fence about air brakes. sometimes I think they will be fine, other times i feel like they are too much work.
My general questions are:
- If I absolutely HAD to, could I get someone to rip out the air brakes and put in hydraulic, or is that easier said than done? (Answer as if I have the money to do that! Haha)
Maybe that's the only question. It's quite expensive to get my license and do courses for airbrakes.
I don't plan on traveling off the bat, but I may go in the future.
Besides an insurance place, where should I look for the best tips and info on airbrakes?
What are the main pros and cons?
Also I feel pressured in this decision because I found my perfect bus and I know nothing about airbrakes!
Thank you for any help!!
Message me if you live near Vancouver B.C, we could exchange tips and tricks on bus conversions!!
Email me: billie_joe4444@hotmail.com
xJP is offline   Reply With Quote
Old 10-25-2013, 02:13 AM   #2
Re: Airbrakes Discussion
Here in Texas it doesn't matter if it has air brakes or not Hydraulic brakes. We do not need a special license, where are you? Are you sure you need an air brake endorsement on your license? it seems to be state to state as to the rules, it may be way less complex than you are making it.
Malkieri is offline   Reply With Quote
Old 10-26-2013, 01:13 PM   #3
lapeer20m's Avatar
air brakes are more simple and reliable than hydraulic, not to mention they stop so much better.
nearly Every single semi-truck on the road has air brakes. If they were complicated, or problematic, or didn't have tons of stopping power the industry would not use them.
Michigan does not require any special endorsements for non-commercial vehicles with air brakes. I imagine other states have similar laws.
another advantage of air brakes is that you can use the air to fill tires and run air tools.
Newer style air brakes have automatic adjusters. Older air brakes require a 9/16 wrench to adjust/check. It literally takes 30 seconds or less per wheel to adjust the brakes. I'm sure there is a youtube video that shows you exactly how to do it. It's very simple.
Old 10-28-2013, 03:27 PM   #4
Chassis: TE2000 FE
Engine: 5.9L Cummins
with the weights most conversions reach air brakes are needed, so its better to learn how to use and adjust. Or spend time at various truck stops along the way
Chuck
cschlessman is offline   Reply With Quote
Old 10-31-2013, 07:10 AM   #5
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
With air brakes if they fail your gonna know it BEFORE you need them
Old 10-31-2013, 10:20 AM   #6
wmkbailey's Avatar
Engine: 3126
Most buses now days the parking break will engage when you lose air presure.
When you get to the limit of your break pads, you notice when using the parking break at stops. It wont hold as well when they get worn down.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-04-2013, 10:12 AM   #7
I just picked up my second bus, which has air brakes. I was a little trepidation at first, hearing the same things you've been hearing, but I haven't noticed a difference while on the road. One feature, that is pretty neat is that when an air system is not pressurized, the brakes are in the brake position, and it requires air to unlock. This means you can't even start moving if you have a brake issue, or if you have a failure on the road, the vehicle will brake to a stop. Also makes a handy parking brake.
icnivad is offline   Reply With Quote
Old 11-18-2013, 07:42 PM   #8
Coachwork: Amtran Volunteer
Chassis: IH 3800
Engine: DTA 360
Air brakes are superior to hydraulic on anything over 18,000 gvw.
If you have air brakes, get with a QUALIFIED heavy truck mechanic and have him walk you and your partner (needed for a proper inspection by applying the brake pedal while you inspect) through the inspection and adjustment process. It is not that difficult.
The only real problems you may encounter on a normal inspection is a stuck automatic slack adjuster, a bad spring brake can, or air leaks.
Doing this type of work yourself can also help motivate you to crawl under the bus and check for other problems that can affect the safe operation of the vehicle (leaky wheel seals, broken suspension, etc.).
mechanista is offline   Reply With Quote
LED headlight discussion Stu & Filo. T Conversion General Discussions 4 04-05-2014 09:59 AM
Off-topic stuff pruned from Conversion Discussion ol trunt Everything Else | General Skoolie Discussions 13 02-10-2013 04:57 AM
Short TC2000 with 5.9/MT643 and Airbrakes? bus-bro Everything Else | General Skoolie Discussions 1 12-18-2010 09:13 PM
Reviving Heat Pump Discussion. Locutus Conversion General Discussions 5 05-21-2010 03:35 PM
1996 INT DT466 Airbrakes fully converted. JoeA Classifieds | Buy, Sell, Swap 0 11-21-2006 11:06 PM
