Old 02-11-2008, 09:56 PM   #11
Re: alternative to PEX crimpers?
some plumbing stores will rent out crimpers for cheap. all you'll need to do is put down a damage/theft deposit and it will be returned to you when you bring it back
garrett is offline   Reply With Quote
Old 02-11-2008, 10:59 PM   #12
Elliot Naess's Avatar
Engine: 5,9 Cummins
A local plumbing supply store just told me that PEX varies in diameter by brand, so this may be a factor for the push-together fittings. What he showed me were short lengths of thick stiff PEX, maybe five feet long, versus long coiled-up PEX that is more flexible but thinner, and the shark bites may not get a good enough grip. These were both labled 1/2 ". Sound right?
Old 02-12-2008, 07:25 PM   #13
I used the shark bite fittings from HD...Very happy with the results..Little pricey,,But for speed and easy no leak conections its the way to go...Oh dont forget the fitting release tool screw up and you cant pull it apart..its about 79cents and worth every pennie....
colliervilledave is offline   Reply With Quote
Old 02-12-2008, 10:39 PM   #14
Well I solved the same predicament by buying the tool then returning it. I couldn't find one to rent around here and yeah they're just too expensive.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Mr Heater alternative. crazycal Everything Else | General Skoolie Discussions 4 12-02-2013 10:15 PM
Alternative ceiling material chaos Conversion General Discussions 6 03-09-2010 10:38 PM
Alternative Fuel?? drchefscott Veggie Oil | WVO | Biodiesel | SVO 11 02-21-2009 05:22 PM
Alternative Energy paul iossi Conversion General Discussions 6 04-11-2008 02:27 PM
Alternative plumbing pangaia Skoolie Conversion Projects 7 01-24-2005 02:04 PM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
