09-13-2018, 06:28 PM
Coachwork: Girardin
Chassis: Ford E350
Engine: 7.3L Powerstroke Diesel
Alternative to Well Nuts for Mirrors
Hey all,
We removed our crossover/side mirrors to paint our skoolie and they were attached with what we are now learning are Well Nuts. The old ones don't seem to be reusable. We tried to pick up some replacements but the flanged portion seem too small but they were the only ones I could find that fit the existing bolts. Are there any alternatives to attaching the mirrors?
Thanks!
09-13-2018, 06:46 PM
What size are they? The hole for a well nut is too large to replace with a blind nut.
09-13-2018, 06:51 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
alternatives
riv nuts, make a nut plate -- look it up, bolt and nut if you can get to the back side? rivets? weld/braze?
william
09-13-2018, 10:00 PM
Rated Cap: 37,400 lbs GVWR
Jack Nuts, or their much stronger cousin Cross Nuts (made by Bolhoff). I've bought some of the latter to attach my overhead cabinets to my roof ribs.
09-16-2018, 12:28 PM
Coachwork: Girardin
Chassis: Ford E350
Thanks, I'll check those other options out. I've only found Well Nuts locally with about a 9/16" flange on them. The original ones looked much larger.
09-21-2018, 10:59 PM
Interested in the outcome here. I'd never heard of well nuts but after looking them up I'm wondering if they were spec'ed in this usage to reduce the transmission of vibration to the mirrors. You're obviously not going to get that with any normal all-metal bolted connection solution.
09-22-2018, 07:52 PM
You are correct, which is why I haven't come up with a "proper" alternative. I am trying to theorize the issue and unless the hole in the bus has been enlarged I don't see an issue. I would like to see a pic of the old well nut in the hole. A Wellnut works the same as a pop rivet. As you tighten the screw/bolt the nut at the end of the rubber tube starts to pull forward distorting the tube enlarging its you tighten. The flange on the other end also squashes enlarges. I think if the replacement Wellnut flange is shallower it won't matter as it's only use is to keep the unit from falling through the hole. If the actual bus hole has been enlarged, then go up a size in welts and redress the mirror holes.
09-22-2018, 07:53 PM
I wonder if yours look larger because they've been compressed for 15 years?
Post a pic of the nuts and holes.
09-22-2018, 10:40 PM
Chassis: Blue Bird
Engine: ISC 8.3
Did you find something that fit? I see that Hanson Rivet has a selection of well nuts including one with a 1/4-20 thread and a 9/16 flange diameter (their part RN-2520-13).
09-27-2018, 04:54 PM
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
I found mine at the local ACE hardware store
They were a rubber expansion type nut insert
09-27-2018, 05:22 PM
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
My mirrors are simply bolted in, and it shows when I'm up to speed on the highway.
Not to hijack the thread, but I'm looking for new mirrors for my rig.
09-27-2018, 05:28 PM
Try mounting them with wellnuts.
09-27-2018, 09:56 PM
Rated Cap: 51,600
Now that I know what wellnuts are, yes I will.
Still would like new mirrors, though. The ones currently on the rig are small and rusted.
09-29-2018, 08:59 PM
Coachwork: Thomas MVP
Engine: Cat 3126B
Rated Cap: 20800
Source of bus mirrors
I have received great service and quality parts from these folks.
Mirrors
09-30-2018, 05:31 PM
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
Originally Posted by that web site
Please log in for price
I hate that crap.
10-01-2018, 04:38 PM
Rated Cap: 51,600
Originally Posted by Marceps
I hate that crap.
Ugh, so do I.
