Old 05-15-2019, 07:57 PM   #1
Coachwork: international
Chassis: Front engine
Engine: mechanical DT466
Rated Cap: 71+
Angle grinding for rivets and rust
Hi guys,
I recently picked up a 4 1/2 angle grinder. Any advice on what type of discs (what grit) were useful for everyone? I plan on grinding off the bolts holding the seats down and possibly going at the rivets with it (if the air chisel doesn't work). What types are good for cutting ? Sanding down rust? Any things to avoid when grinding? Im brand new.
Thanks as always
Thetireddad is offline   Reply With Quote
Old 05-15-2019, 08:07 PM   #2
Cut off wheels are usually 1/6" +/- thin and use the edge for cutting. The grinder wheel is usually much thicker and use the face to remove metal from surfaces. You don't want to use cut off wheels as grinder wheels using the face, they can explode with injury causing force. PPE for either. If I was using the angle grinder to remove seat bolts I would use cut off wheels and cut through the bottom of the bolt head. I highly recommend buying the discs in 10 packs, multiple packs. They're not real expensive that way, and cutting bolts will eat them pretty fast.
File Type: jpg Grinding_Wheel_10_Pack__00431.1518107547.1280.1280.jpg (87.2 KB, 2 views)
Old 05-15-2019, 08:13 PM   #3
Rovobay's Avatar
Rated Cap: 35
https://www.amazon.com/Bionic-Shield...ateway&sr=8-10
safety first.....
cutoff wheels work but are fragile to work with especially if you have never used an angle grinder before.
griding wheels are thick and work. a flapper disc is also great.
https://www.amazon.com/WORKPRO-20-pa...gateway&sr=8-4
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 05-15-2019, 08:15 PM   #4
Originally Posted by Thetireddad View Post
Hi guys,
Thanks as always
Walter zip wheels: https://www.amazon.com/gp/product/B01HPRS1OM are great for cutting, they last longer and you can cut easier and straighter than the ones at the big box store like DeWalt etc. Even this 10-pack will probably be more than you need, but it never hurts to have extras lying around.
Trying to remove rivets with an angle grinder is probably a dead end. It takes too much time and effort per rivet and there are too many rivets.
Old 05-15-2019, 08:42 PM   #5
Not true. Some of the rivets HAVE to be ground off.
Roll Your Own Build Thread
Old 05-16-2019, 02:08 AM   #6
Coachwork: Blue-Bird
Chassis: TC RE 3408
Engine: 5.9 Cummins 12V Mechanical
I am not finished yet, but I have been pulling rivets out. First, I use a punch to drive the mandrel out, Although driving the mandrel out is not really necessary with aluminum rivets, it is necessary with the larger steel rivets.
The first time I attempted to cut a rivet head off with my cold chisel I realized it would be much easier and quicker to raise the rivet just enough to get something to pry with underneath the head than it would be to cut it. So I never cut a single rivet. At first I tried a claw hammer, but I switched. Now after the mandrel is out I hold the crooked end of my little pry bar that has a sharp v-notch next to the rivet head and tap the prybar with my hammer to drive the prybar under the head of the rivet. I often have to do this from 2 or more directions before I can get the head up just a bit, but after I can get the prybar all the way under the rivet, I just pry the rivet out.
It takes a lot more time to describe this process than it does to do it. There are some rivets that are much more difficult, but most of the rivets come out easily in 20 to 30 seconds. My method is still evolving as I finish up with the rivets in the walls and start on the ceiling. I have taken some pics but have not yet figured out how or where to post them. Guess I will do that soon.
gs1949 is offline   Reply With Quote
Old 05-16-2019, 09:15 PM   #7
I had to remove a lot of bucked rivets and on most of them the best method turned out to be grinding the head off with a flap disc and then punching the body out with a punch.
Regarding cutoff wheels. I had some Norton discs on the shelf and started working on my bus with them. Then I bought some from Harbor Freight. I can look at cuts I made and tell you which disc I used on that cut. The Norton discs cut easier and straighter than the HF discs. They also lasted longer.
Old 05-17-2019, 04:36 PM   #8
Chassis: TC RE 3408
I've never tried flap discs. What brand and grit number did you find best for removing rivets?
Old 05-17-2019, 04:39 PM   #9
Norton 60 grit.
Old 05-17-2019, 04:43 PM   #10
Chassis: TC RE 3408
Thanks for the quick response.
angle grinder, grot, rivets, rust, sanding
