Originally Posted by MambaJack
Is it a nono to have propane appliances in a bus if you also have a wood stove?
I sure hope not! We've got the Cubic Grizzly stove, it's right next to our propane range....but we've installed a propane leak detector as well as a few shut-off valves for the oven, the water heater, and one for the whole system. If you're worried about things going BOOM, I'd suggest putting some valves in where you can shut off the gas.
The Cubic is a nice stove, and we're still learning the ins and outs of it. We've got a much larger wood stove in our home, so we know our way around them. The Cubic takes much smaller chunks of wood, and heats the bus nicely, but we only get maybe 90 minutes of burn time before we need to load it up again. Still playing around with the damper and getting to learn it better....perhaps we'll be able to slow the burn and get more time between loads. We'll find out in the next month or so when we take an extended trip.
