Old 12-23-2017, 08:47 PM   #1
plfking's Avatar
Rated Cap: 34
Any idea what this was?
There was one mounted on each side of the lower rear wall of the bus. Before I delete the wiring, I was wondering what it was for, in case I want to re-install it.
To me, wiring always means lights.....and there's always room for more lights.
Don
Old 12-23-2017, 09:02 PM   #2
Robin97396's Avatar
It must have been something school related if they pulled it off. Kind of low for clearance lights.
Robin
Nobody's Business
Old 12-23-2017, 09:15 PM   #3
Turn sig...??? Don't see one in the pic.
Old 12-23-2017, 09:33 PM   #4
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Rated Cap: 16
That's about where the reverse light are on mine...
Sent from my SM-G950U using Tapatalk
johnbloem1974 is offline   Reply With Quote
Old 12-23-2017, 09:43 PM   #5
golfersmurf57's Avatar
Backup lites? Would be one per side
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 12-23-2017, 09:54 PM   #6
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I'd prefer a light bar for backup lights. Regular lights just don't perform as well.
Old 12-23-2017, 10:58 PM   #7
plfking's Avatar
Rated Cap: 34
I like that idea.
Thanks for the insights......I could've posted a bigger pic to start with. I guess I'll agree it must be backup lights, since that's all that seems to be missing........but why would the school remove those, when they left the stop sign on?
I'll keep the wires and look for small backup lights.....I'll be needing some of that area (on the passenger side) to mount my swing-out bike carrier (like the tire carrier I had on my old CJ5), plus I plan on extending the rear bumper 14" to serve as a mini-porch/ladder-to-roof-deck access/tool storage bin. Be better to wait until that's done before figuring out where to mount a light bar.
Thanks guys! As always, you rock.
Don
Old 12-24-2017, 04:33 AM   #8
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Well, whatever was on there wasn't heavy- just 2 little screws. Wasn't a camera
by the wire, looks like a light-- like others have said.
The only time sellers remove equipment is:
1) Proprietary tech
2) Was $$--going to reuse/resell
3) Illegal for public- sirens, emergency lights, markings
"Pat, I'll take #3 for $200"
I say they were LED flashers. They sell some nice, self contained units that have all the electronics inside.
Old 12-24-2017, 10:47 AM   #9
Your bus was decommissioned and your lights were poached for another bus in service.
Old 12-24-2017, 12:50 PM   #10
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
You can hook a meter to the wires and go through the functions to see what switch or motion sends power to them?
Of course with the backup lamp it would be safest to have a helper even with air brakes.
Good luck
Old 12-24-2017, 12:52 PM   #11
Year: 86
Chassis: Ford B700
Engine: 8.2
Also in the position that they are in they could have also been license plate lamps?
Old 12-24-2017, 03:43 PM   #12
That's definitely where the booster cables clamp on when in the swamp!
Drive more carefully and you'll never need them.
