Old 05-05-2013, 02:27 PM   #1
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Anyone ever use Hy-Tech#85 Barrier Coat
I am going to be getting ready to put windows in soon. I was thinking of spraying this on the inside of the bus before I either spray foam or use poly iso?
By the looks of it... it should sound dampen to some degree.... vapor barrier....and obviously radiant barrier?
http://www.hytechsales#85%20Barrier%...om/prod85.html
The coverage rate is : 200 sq ft per gallon (for attic spray applications) So Im thinking maybe 2-3 gallons? I will probably be ordering the 5 gallon bucket just to be sure I have enough on hand?
Any other thoughts please feel free to put them here?
Old 05-05-2013, 11:16 PM   #2
roach711's Avatar
Rated Cap: 19
Re: Anyone ever use Hy-Tech#85 Barrier Coat
Many here have mixed the ceramic spheres into their exterior roof paint and report greatly reduced heat gain on sunny days so this product sounds like it would work also.
The Roach Motel
windshield wiper tech bansil Conversion Tutorials and How-to's 2 07-03-2013 11:18 AM
Hi-tech Insulation Gulfcoast Conversion General Discussions 1 03-24-2012 08:14 PM
Vapor Barrier question jbus Conversion General Discussions 2 07-27-2010 10:42 AM
Exterior Finish - Fiberglass bonnet - CLEAR COAT REMOVAL jpf411 Conversion General Discussions 9 09-12-2006 11:33 PM
Low tech refridgeration rabiznick Everything Else | General Skoolie Discussions 1 09-27-2004 07:44 PM
