Old 06-04-2007, 08:12 PM   #1
Anyone ever used the bifold door as camper door ?
I did some serious thinking and measuring of the bifold on my TC2000 tonight.
I'm thinking I can flip the door over to get the cross bar low enough for a handle mount from outside, turn the hinge around so it will work all the way outwards, weld the two door halves solidly together maybe remove the middle hinge and weld a patch over, and put a recessed handle in it. I'd have to build a door sill and frame with seals, but I think it all works.
I have been agonizing ( sort of ) about a door that works from both inside and outside and looks good, but is secure on the road ( safety glass ), and allows me to see when I come to an intersection. I think this will work.
Comments ?
Rick
RichardRWatson is offline   Reply With Quote
Old 06-05-2007, 01:20 AM   #2
eggman's Avatar
Re: Anyone ever used the bifold door as camper door ?
Exactly my thoughts. I am going to weld a 1" square tube in between the two door halves, after removing the glass of course, as well as flip the hinge around. My plan is to also use the rubber seal on the front outside of the hinge to cover it, then use a half bulb rubber auto seal for the rest of the door. Only thing I can see that would cause any trouble is the top of the door. Might have to create a place to mount the seal to keep out the weather. Hadnt thought about a lower door sill for sealing up the bottom of the door. But that shouldnt be too hard to do, possibly one from home cheapo or lowes made out of aluminum.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 06-16-2007, 02:53 AM   #3
eggman's Avatar
Mine is now underway.
More can be seen here.
http://www.eggmanih.com/ihbus/doorbuild.html
Jeff
Old 06-16-2007, 11:02 PM   #4
eggman's Avatar
Here is the door from the outside in the daylight. It will swing all the way open to the mirrors.
Jeff
Old 07-02-2007, 04:09 PM   #5
I dove in and modified my door today. I wen the minimalist route for now. I will hopefully get back to it and weld on some smooth sheet metal on the outer surface to replace the middle hinge.
Took me about an hours work to get to this point. I'm on a tight schedule to be able to do some camping this summer. Actually we just spent two nights in the bus this weekend away from home, but no cooking or washroom. Three more weeks and we need to spend a week in it in the woods.
http://www.skoolie.net/gallery2/main.php ... &g2_page=2
Rick
Old 07-04-2007, 09:26 PM   #6
GoneCamping's Avatar
double posted, delete this one please...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 07-04-2007, 09:27 PM   #7
I scrapped the bus door, and installed a Larsen Security Door, it has triple locking mechanism, tempered safety glass with membrane (like front windshields), and is virtually break-in proof...oh and it has full view too!
When I measured the bus door opening and found it to be 32" and then looked around at Lowes and found this door would fit, and the glass and triple locking set-up should meet DOT specs...
*Cliff*
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
Replacing bus door with storm door??? leadsled01 Short-Bus Conversion Projects 13 03-18-2014 07:31 AM
Replacing the door with ext house door? jkronmiller Conversion General Discussions 2 06-10-2013 02:05 PM
bifold door/security? THANKS! chanceyears Short-Bus Conversion Projects 2 03-31-2010 07:20 PM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 11:56 AM
