Old 09-15-2017, 05:04 PM   #1
Clayton's Avatar
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
Anyone here know how to analize transmission oil sample test results? Its Greek to me
Anyone here know how to analize transmission oil sample test results? Its Greek to me. They give you a simple interpretation but it does not tell you much. The transmission is a 1996 Allison MD3060. Please see attached.
Clayton is offline   Reply With Quote
Old 09-15-2017, 06:31 PM   #2
A fancy way of saying fluids "Normal" to me.
What's the 230 litre capacity about though? Is that right for that tranny?
Old 09-15-2017, 06:36 PM   #3
Clayton's Avatar
I seen that also. Its not 230 liters, can you imagine that oil change? HAHA
Old 09-15-2017, 08:31 PM   #4
I can't even guess what that means. Even 23 sounds a bit much but maybe so.
Old 09-15-2017, 09:53 PM   #5
Clayton's Avatar
I think 23 liters is right. I have not changed the oil. I was hoping this test would tell me if I need to change the oil and what type was in there... But nope.
Old 09-15-2017, 10:02 PM   #6
roach711's Avatar
Rated Cap: 19
Use Blackstone Labs next time for your oil analysis. They give much better information.
The Roach Motel
Old 09-16-2017, 08:12 AM   #7
This might help with a breakdown... Other than that, I don't know what your analysis means either as there's no interpretation key or baseline.
Black stone explanation https://m.blackstone-labs.com/ReportExplanation
Old 09-16-2017, 09:22 AM   #8
turf's Avatar
Blackstone will write out their findings on the lab results in a comment section of the test results. thats about the only difference between the 2 companies.
the only number that is alarming is the Iron number. one sample isn't enough to judge whats going on, but that's the one number that would indicate problems. with that result, i would drain the trans, pull the pan, clean up the magnet inside the pan, refill and test again in a year.
if the number is high again, you probably have some wear issues. it may be that high just because the magnet full of metal bits.
impossible to tell from 1 test.... you need a history of tests to make meaningful use of the results.
good luck
Turfmobile Build Thread
