Old 03-05-2016, 07:45 PM   #1
Appliances
Doing some research on appliances right now.
I found mention of the Thor Washer/Dryer combo. The only negative consistent comments I have seen is load size. I am a single guy, it will just be me so I don't think that is an issue. Aside from load size has anyone heard anything else about the Thor unit? Would you prefer another combo?
Where the refrigerator is concerned I would like one that has a choice of power sources (propane, direct electric or battery). Several have been listed on craigslist but they are always ones out of an RV being scrapped or parted. Is it better to buy new or do those units in general have a good shelf life?
Thanks for any suggestions and help.
Started the account for the bus, only a couple hundred in there now but will save that much each check. Getting pretty excited.
BigPaul is offline   Reply With Quote
Old 03-05-2016, 08:42 PM   #2
I've got a washer/dryer I'm about to stick on CL for cheap. Where are you located?
Old 03-05-2016, 09:16 PM   #3
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
my friend had a non vented combo,he said it takes forever to dry. as far as the rv fridge they have to be perfectly level to operate. read this.
Gas Electric Refrigerators
my build pics
Old 03-05-2016, 09:21 PM   #4
The one I have is vented just like a home unit.
Old 03-05-2016, 09:53 PM   #5
East Coast CB, I am NE of Atlanta about 30 minutes but not in a position to buy one right now.
Just started back to work after a long illness, but getting stronger everyday and doing well.
Thank you though.
Old 03-06-2016, 06:01 AM   #6
Ok, man no worries. Sorry to hear about your troubles but glad to hear you're getting back to work.
Old 03-06-2016, 08:38 AM   #7
WanderingLass's Avatar
Year: 1969
Chassis: Ford B-750
Engine: 390 BB
Rated Cap: 2 humans, 1 cat
We're a couple and I am a lady of generous size We have in our apartment a Panda XPB36 and we love it. It's a twin-tub washer; agitates on one side, spin on the other. We hang our clothes to dry and even in the Ohio humidity in the summer, it takes about a day to dry (way less, of course, in the winter when they're hanging over a floor vent!). It takes between 32-40 gallons of water a week to do 4 loads of laundry on the weekend. We've had it for not quite a year and still love it. It's manual, you can't just "set it and forget it," but it saves on laundromat costs and feels a lot easier on the clothes. We did have to buy lint filters for while it's washing, otherwise there was a lot of lint still on the clothes.
When we get Wanda the WanderingBus home, we have a closet in there that we plan on using partly as a drying closet so we'll do laundry daily-ish and hang the clothes in there with the window cracked for air flow. It's currently on Amazon for about $140.
WanderingLass is offline   Reply With Quote
Old 03-07-2016, 07:45 PM   #8
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Only appliance I have bought for the Hog is my single serving kurig.........
Old 03-07-2016, 11:47 PM   #9
Dual tub uses a lot less electricity than a combo. Where do you plan on getting your electricity?
pengyou is offline   Reply With Quote
Old 03-08-2016, 09:15 AM   #10
Year: 1969
Chassis: Ford B-750
Engine: 390 BB
Where we're moving in April is an RV/mobile home park so we'll have full hookups at $460 a month. We'll figure out long term plans once we're working again.
Old 03-23-2016, 11:46 AM   #11
Did you end up putting that W/D up? I'm located in FL.
bwhite320 is offline   Reply With Quote
Old 03-23-2016, 12:19 PM   #12
Its in my storage building. Come have a look anytime.
Old 03-23-2016, 12:38 PM   #13
Can you send me an image of it? Please and thanks
Old 03-23-2016, 01:58 PM   #14
Yeah, it will be a day or two though.
Old 03-23-2016, 04:02 PM   #15
Rated Cap: Your mom +1
Or on the alternative side there is the $49 Wonderwash which uses no power and takes up relatively little space. With that you could use a spin dryer. There's one on the market from "laundry alternative inc" that uses just 190 watts and can take a 22 lb load of clothes for only like $160. They also make a smaller counter top version of the same dryer for about a hundred bucks less...
Old 03-23-2016, 05:26 PM   #16
This is from google images, but its the model I have-
