Old 05-01-2012, 09:02 AM   #1
Re: audio wiring question
Most modern school busses have pa system in them, but prison bus may be different. Also, most all wiring is initiated at the point above the driver's head, as that is where the radio and often the 2 way system back to the district is located. you probably gotta take off the upper panels for that part. If you are wiring in a jack and a rheostat by each speaker, i think all you gotta do is to remove the speaker, extend the wires as necessary, put the volume control in line first, and then your jack, and speaker. you would need enough extra length of wire so you can assemble it. Ya also gotta drill the holes for the 2 extra devices close to the speaker hole and re assemble after you have tested it for operation.. Not hard, but gonna be time consuming. You could also bring those controls out on the little L shaped brackets and screw them to the ceiling, but it wouldnt look as clean. And if you want to get really elaborate, run the wiring, etc into the back of the seat in front of each passenger....
Old 05-01-2012, 05:45 PM   #2
why not just have a separate dvd amp for the seat headphones and keep the radio/pa system in the overhead speakers? I dont think in that case you would need mini amps.. just like a 50w one like i have which runs my speakers just fine.
Old 05-02-2012, 07:26 AM   #3
bapos's Avatar
Chassis: 2001 International RE
Few thoughts....
On a PA... I would just use a cb radio that has a PA output. Connect this to a amp that has line level speaker input versus rca input? This is what I am planning out doing for the extrnal speaker for PA. Its more to mess with people that an actual purpose. Kind of like the Mr Microphone commerical? This would also help if your in trouble and no cell coverage.
As for headphone. You may want to look in to headphones that use IR to get their signal. This would solve your connection problem and not have to deal with wiring up jacks to each station. If you do wire it up you will need some type of impeadance balancing possible. You just cant tie them all together. The resistace will smoke the output of the amp. I may be wrong here but just thinking out loud. If it were me.... I would be looking for some type of multi selectable input switch as well as types of output. That way you can choose your source input (dvd, cd, ipod,etc) and what you route them to external speakers outside the bus. inside bus, headphone jacks, PA system?
I am going to use some of these same thoughts so Ill be on the look to see if I can find some of these things. I am a ways away but ill look now.
Old 05-02-2012, 09:24 PM   #4
WHAT are you guys talking about?? My 8 track still works just fine--as does my Comador 64.
Old 05-04-2012, 08:21 AM   #5
bapos's Avatar
8 track... your fancey.... Im still kickin the 78 lp records.
Old 05-04-2012, 10:55 AM   #6
i bang on a tree with my rock...
Old 05-04-2012, 10:02 PM   #7
'49, I just climb the tree and pick the coconuts! BTY My grandmothers "crank" type phone works just as well as my comadore 64. You just tap the hang up 6 times for 6 and 3 times for 3 etc you get the picture? and the call isn't traceable for billing! TOP THAT!
Old 05-05-2012, 02:04 AM   #8
Can anyone help with re-wiring in NYC? sebjaram Conversion General Discussions 1 09-09-2014 11:40 AM
Wiring question rjwojton Alternative Fuels | Electric, Propane, Wood Gasification, etc. 3 07-19-2014 11:23 PM
Electrical - wiring Question swinada Conversion General Discussions 11 05-25-2008 04:04 PM
DC wiring question reprobate Conversion Tutorials and How-to's 3 12-27-2007 07:55 AM
50 amp ac wiring captainkf Conversion Tutorials and How-to's 1 10-30-2005 08:12 PM
