Old 12-03-2009, 06:00 PM   #1
Elliot Naess's Avatar
Engine: 5,9 Cummins
Automatic generator on-off?
When we go places with Millicent, specially Burning Man, we have all kinds of uses for 110 Volt AC power -- but rarely for very long at the time. So we fire up the Honda EU3000 -- and then we have to remember to shut it off again.
Recently, a pretty good idea came along for a very efficient electric refrigerator; buy a chest freezer and use it as a fridge with an added-on thermostat. The anticipated 110 consumption was something like a few minutes per hour. And the EU3000 would have enough power.
But how to make the EU3000 start and stop as needed? The technology no doubt exists. Refrigerated 18-wheelers work that way.
The EU3000 has a starter with a key, like a car. But it also has an old-fashioned manual choke, which could be a problem to automate.
Any of you electrical wizards...?
Old 12-04-2009, 12:58 AM   #2
Re: Automatic generator on-off?
another thought-
over on one of the truck conversion sites that i follow, 1 guy claims that he uses a chest freezer, runs it about 1 hr a day to keep it frozen and then uses a cooler for refrigerator/daily use.
My thoughts, use a 7 or 10 ft chest freezer, keep at least 4 gallon jugs of ice in the coldest part, rotate 1 or 2 of them into your day cooler every day, try to keep them from melting, freeze everything that you can freeze in advance and move what needs to thaw to the cooler a day ahead of when u want to use it.
try to open the freezer only once or twice a day,add a layer of insulation around the outside of the freezer, use/build a super insulated cooler.
also look at the coldplate refrigeration systems that they put in cruiser type sailboats for ideas
Old 12-04-2009, 01:34 AM   #3
the_experience03's Avatar
Top link.
http://tinyurl.com/ylyh24k
*edit* Upon further reading it would appear that this one is better. http://www.sunent.com/miscpage_007.asp
Old 12-04-2009, 02:03 AM   #4
Do a quick search for Sun Honda Remote Start and you should end up with:
If you go down the page you will find a PDF that gives instructions on how to install their Remote Starter in the 3000, I am just not sure if its a generic kit or you have to find a model specific kit. *edit* Right above the PDF is a pair of Ebay links, the kit is the left one.
The PDF:
http://www.sunent.com/images/SUNENT/...onInstruct.pdf
Old 12-04-2009, 12:59 PM   #5
Engine: 5,9 Cummins
You folks are marvellously helpful!
Looks like both the Hayes and the Sun have an actuator for the choke. The Hays plugs the wiring in, while the Sun requires soldering.
The automobile type might also be worth looking at -- had not thought of those.
But I would still need to get rid of the wireless feature and replace that with something that senses when power is needed. These wireless thingies do nothing but save me a short walk. I don't mind the walk. I'm looking to completely automate the process. And preferably by good-old-fashioned hard wires.
So... so far we have solved half the question. We have found hardware that will operate the ignition switch and the choke.
But I would like to be able to leave camp in the morning and still have hard ice cream in the evening -- without running the generator all day.
Hmmm... Maybe the best answer is to build the chest freezer into a box with 12 inches of extra insulation on all sides, and then I might not need to run the generator more than two or three short times a day, when I'm in camp anyway?
Maybe I have cancelled my own high-tech question with some plywood, styrofoam and common sense?!
Yes, I do enjoy brainstorming.
Right, a generator should not be started with a load on it, so it would need the delay relay mentioned above.
These wireless "key fobs" scare the heck outta me. No such demonic device shall ever be used in Millicent! I have seen too many garage doors open by themselves when nobody was home.
All right -- it's warming up outside, so I can work on the barn.
Old 12-04-2009, 09:19 PM   #6
so, it's really all about the ice cream , as previously suggested, reseaarch the cold plate technolog that they use in sailbouts, it's actually derived from the early dairy/milk delivery trucks, you are also on the right track with the super insulated freezer box. thirty years ago while i was in florida i built a super ice chest/cooler to use at weekend long island parties, 3 inches of polyiso insulation enclosed in fiberglass and then installed in a plywood box to protect it 2'x2'x4' approximately 60 gallons, put it in the boat & then filled it up add some dry ice on top keep it out of direct sunlight and only open it a couple of times a day, worked real good and is still in use in fl buy the now middle aged party crowd.
if you want to do a freezer, find a hvac dude to help you get the compressor and condensor outside of your thermal envelope, also look around for used walkin cooler/freezer panels to assemble a custom thermal box out of.
the other thing is it really helps to keep the box as full as possible, anything to keep air exchanges to a minimum
Old 12-05-2009, 12:30 AM   #7
Engine: 5,9 Cummins
The E-Z Kold Kottager units with "cold plate" technology looked interesting -- until I saw that they cost around three Grand.
I'm thinking more like a $300 Sears unit plus some styrofoam and whatnot.
I like the idea of relocating the compressor and condensor outside the super-insulated "crate". Like a miniature central AC for a house. I know some A/C techs.
I still have the dead full size refrigerator that I laid on its back to hold Dry Ice in 2008. Might be able to put a small chest freezer inside it, and pack the void with insulation and thermal mass.
Yes, there SHALL be ice cream all week! (And I don't trust propane).
Good brain storm! Thanks!
Old 12-06-2009, 05:37 AM   #8
Read the "Cross Time Engineer" series by Leo Frankowski...Just do a search for Conrad Stargard and you should have no problems finding them...
But, in the book, he makes Ice Houses by making a huge building with a smaller building inside, then packs the middle space with sawdust and hay. It would then keep ice gathered in winter just long enough to go gather more the next winter. I remember reading in some history book in highschool that this method was used. I bet (guess) that 6" of sawdust would work for a day.
I wonder if there is a box that when it detects a loss of power, it can send a pulse, and another pulse when power comes back... Wire it to the remote, let it hit the buttons electronically.
Old 12-06-2009, 07:47 PM   #9
Engine: 5,9 Cummins
There must be hundreds of old county roads around this nation named "Ice House Road". And that's pretty much how those facilities were built, yes.
Surprise -- they taught you something true and useful in high school!
I'm now leaning towards super-insulating the freezer with extra styrofoam, and turning the generator on manually just a couple of times a day. I can buy huge blocks of styrofoam fairly inexpensively at a local factory.
It is not unusual that I talk myself out of my own ideas!
Old 12-06-2009, 08:18 PM   #10
check on the R value of any insulating foum and opt for the best insulation, probably polyisocyanite, the brown stuff
Old 12-07-2009, 06:37 AM   #11
Wasnt anything I learned in HS. I learned it about two years ago from that book series. I just happen to remember glancing over "ice house" and "filled with straw". I put it together when I read the books.
Old 12-07-2009, 01:12 PM   #12
This has been tormenting me, Elliot. Rest assured I've been trying to come up with a circuit using cheap off the shelf parts that will work, but I just can't seem to make it happen without an expensive little black box of some type. I think your plan of manually starting the generator a few times per day with the remote is the best solution you're goign to get short of spending as much as you paid for the bus itself.
Old 12-07-2009, 01:49 PM   #13
Engine: 5,9 Cummins
Thanks for your efforts, Andrew!
But the silly thing is, the LAST thing I want is a remote control. I can walk 40 feet and turn the key just fine. What I had in mind, was to automate the process so the ice cream would not melt while I am away from camp for an undetermined length of time.
Sounds like the solution is to insulate the box so well that it will stay safely frozen something like eight hours between start-ups. To encase a chest freezer this well, may require the compressor-and-condensor to be located outside the unit, like a house central A/C system. I think I need to go to a store and look at how chest freezers are actually built.
Old 12-07-2009, 02:54 PM   #14
Perhaps the easiest solution will be to install a 150dB temperature alarm on Millicient's roof. A temperature sensitive circuit to ignite some pyrotechnics certainly would be much easier to do.
*edit* Now if we could install fuel injection on the generator the whole thing would be far, far different. Do some reading on Megasquirt, specifically the Microsuirt variant and let me know what you think.
Old 12-07-2009, 06:10 PM   #15
Engine: 5,9 Cummins
Temperature alarm... Oh yes -- one of those Cold War air raid sirens powered by a Chrysler Hemi!
"Whooooooooaaaaaaaaaa...."
"Pardon me fellas, I need to run by my camp and start the generator before the ice cream melts. Back in an hour."
Now, waittaminitt.... If a temperature reading can start the Hemi Siren, then it could surely start the genny!
Old 12-07-2009, 07:16 PM   #16
thesaltydog24's Avatar
I was just thinking but not sure if this helps. What about the home thermostat idea. all a home thermostat is, is a power switch that turns the furnace or ac on or off. then again any thermostat does this (except the one installed in your chest freezer it needs a source of power to operate) but what I was more interested in was when my furnace turns on, the blower fan doesn't turn on right away it waits about 30 seconds then turns on. I wonder if this type of system could work in your case. I don't have much experience with furnaces and not sure what turns the blower fan on. temp senser or time delay. (probably temp) but any 110v time delay switch should work.
SO
external battery powered thermostat sends signal to auto starter which starts generator
time delay waits 30 seconds or so then connects power from generator to chest freezer (what you would have to rewire to not use its own thermostat but to kick the compressor on when power is turned on) .
after set temp is reached thermostat shuts off generator.
In theory this should work. Electrically I'm not sure, you would want to consult an electrician prior to the build for proper and safe installation and if it would work.
I'll keep looking around for more info.
hope some of this helps
Chris
thesaltydog24 is offline   Reply With Quote
Old 12-07-2009, 07:38 PM   #17
chest freezers are built just like uprights, the advantage is that when you open the door all of the cold air doesn't spill out and let the box fill up with ambient temp air
some of the older upright freezers had the evaporater coils built into the shelfs, 3 or 4 shelfs inside a well insulated and weather sealed box with a modern high efficiency compressor and condenser would be the hot ticket.
disect a wrecked reefer trailer for insulated panels and build a doublewall box sealing all the joints with greatstuff and caulk the interior joints with food grade silicone. a good appliance repair shop should be able to get you door gaskets made to fit your application
talk to your favorite thermo king mechanic, he has all the answers for icecream, you just need to convince him to share them with you
Old 12-07-2009, 08:36 PM   #18
SO
Chris
You are correct thus far and arrived at roughly the same solution I did. The problem comes with actually starting the generator. The signal to trigger the remote starter is easy enough to generate, but one that uses a tach signal or crank timer to start the engine will not have the capability of operating the choke. The ones we found on google have the capability of running the choke remotely, but require the operator to determine when the choke is necessary and conduct the appropriate keystrokes. This is why I jokingly suggested Microsquirt to Elliot. Microsquirt will eliminate the choke and automatically enrich the mixture as necessary so a $40 remote car starter with a simple momentary signal could be utilized. Of course fuel injecting a Honda EU3000 isn't really practical.
Old 12-09-2009, 03:44 AM   #19
It just struck me that we have missed the most important question. How often do people open the door to the fridge/freezer while the power is out. Fridges are made to maintain frozen icecream for 12-24 hours with minimal loss (about 5 degrees per 12hrs or longer)...as long as nobody opens the door.
Old 11-03-2010, 08:55 AM   #20
I could think that it was a remote control or the timer for an automatic generator. However, it was a great featured to the generator. It was easy to use and can give real benefits to the user.
My TV shows appliances
Zander is offline   Reply With Quote
Automatic or standard bluebird90 Conversion General Discussions 20 07-23-2015 06:19 PM
Automatic chains opus Classifieds | Buy, Sell, Swap 3 04-19-2011 11:39 AM
Automatic transmission swap fordsmoker55 GM | Chevrolet Drivetrain 7 03-04-2010 06:41 PM
7.3l Diesel Allison Automatic stevex440s Conversion General Discussions 12 12-16-2007 01:38 AM
Automatic chains vonslatt Everything Else | General Skoolie Discussions 3 01-19-2005 10:25 PM
