Old 03-18-2018, 09:38 AM   #1
Coachwork: 1991 bluebird
Automatic to stick change over??
Curious to see if anyone has done a switch from an automatic transmission to a standard. What are the difficulties you ran into and what else did you have to change? What kind of differences you had in performance and fuel efficiency? Was it really worth it? I'm considering this if I purchase a front engine bus. Also wondering if anyone has done the 6th speed upgrade on the Allison 3060 and tracked the fuel efficiency difference.
jimburke77502 is offline   Reply With Quote
Old 03-18-2018, 01:04 PM   #2
There are a number of threads regarding the automatic to manual swap:
https://www.google.com/search?q=manu...ch=skoolie.net
CadillacKid is probably the resident expert regarding the 6th gear unlock. He has several discussions on the topic.
TrailLifeBill is offline   Reply With Quote
