Old 05-14-2016, 11:05 AM   #1
Question Awning/Roll top tarp?
Hello, Has anyone converted a Roll Top Tarp for a grain bed? All lengths are available either by crank or electric.
Old 05-14-2016, 11:19 AM   #2
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
One of these?
I should think it would be a dandy addition to keep the roof cool, aside from having one for the lawn chairs.
Dapplecreek is offline   Reply With Quote
Old 05-14-2016, 11:48 AM   #3
Engine: Cat 3126e
Rated Cap: 28
I would be interested in seeing that in action on a bus.
Josiahdr is offline   Reply With Quote
Old 05-14-2016, 01:08 PM   #4
Robin97396's Avatar
I think somebody should convert that dump truck.
My insurance lady was explaining to me that some guy had licensed his dump truck with car plates, but she wouldn't insure his dump truck for private use. This was used as an explanation of why buses need commercial policies. That's apples and oranges in comparison.
Old 05-14-2016, 01:45 PM   #5
I meant the long ones.
Trailer Tarp System | Grain Trailer Roll Tarps | SRT-2
Old 05-14-2016, 02:57 PM   #6
Robin97396's Avatar
You'd have to have an additional frame work above the skin of your bus to hold up the tarp to allow air to flow for heat to escape. Or you could cover your roof with solar panels and just enjoy that shade instead of spending money on another tarp.
I agree with CB, tarps don't hold up. I'd like to figure out a light weight deck that would provide shade and/or snow shielding. An extra tin roof?
Old 05-14-2016, 07:06 PM   #7
Square aluminum tube frame with lightweight aluminum diamond plate for deck.
Old 05-14-2016, 07:29 PM   #8
Robin97396's Avatar
That would work. A light weight deck like that would be excellent at reflecting heat. That sounds like a pretty simple fab job on a bus 8' wide. That's six or seven 4'x8' sheets, and I bet that would be a big help in the hotter areas. There are times when a deck up high is nice for a lawn chair, like at parades so you can see over the crowd or when it's muddy and the bus is stuck. So I think I'll put a 26' luggage rack on the top of my bus and deck it with aluminum diamond plate.
Old 05-14-2016, 08:16 PM   #9
Arvik's Avatar
Year: 97
Chassis: BadMuthaFuka
Rated Cap: All of us
i have put some thought into this shade idea. tossed around getting a dozen of super strong earth magnets and rolling reflectix over the roof and magnet it down. not for travel only for at the stand still. you could lap it like shingle style and beat all the leaks too.
https://www.google.com/search?hl=en&...btcotGfbD7M%3A
or maybe just aluminum foiland duct tape!
The road is crazy.
Be safe
Arvik is offline   Reply With Quote
Old 05-14-2016, 10:46 PM   #10
Robin97396's Avatar
I'm going for the aluminum foil helmet, on the bus.
Old 05-15-2016, 03:01 PM   #11
I didn't explain it very good I am saying why not move the rolled up tarp position and use it as an awning to sit under. On the grain trucks the Roll Up Tarp is on the left side of the grain bed. Why not move it over to the right side of the bus so you can roll it out and build awning supports to mount on the side of the bus just like regular RV s have. Should be able to shorten it. They also have electric ones as well.
Old 05-15-2016, 04:11 PM   #12
Robin97396's Avatar
That sounds like an awning that could survive heavy hail damage. Unless you've got a dump truck you can borrow one of those off of, I'm guessing they cost more than an RV awning. Very adaptable if you can get one.
I certainly understand the need for some shade. So far I just use a surplus parachute and ropes.
Old 05-15-2016, 05:07 PM   #13
Large truck scrap yard. I have heard of $350.00 prices. You could make it as wide as you want. Some are about 25-30 ft long on a trailer.
Old 05-15-2016, 08:39 PM   #14
Alan N's Avatar
Year: 1975
Chassis: Gillig
The tarp from a grain trailer would work but it would be heavy and you would still have to build/find supports for the ends.
Interesting idea however. We replace several such tarps every year where I work. I'll have to grab the next one that gets scraped. Just in case.
If you make it work please let us know. Ingenuity and imagination are what bus converting is about.
Alan N is offline   Reply With Quote
Old 05-16-2016, 09:38 AM   #15
I don't have the shop or skills.
