Old 03-01-2013, 08:55 PM   #21
lornaschinske's Avatar
Rated Cap: 89
Re: Awnings on Buses?
We have figured out the only way to get an awning to cover over the entry door would be to use a rope & pole awning. David & I have been talking about it over dinner. So it looks like we may go that route... later.
Fulltime since 2006
Old 03-01-2013, 11:23 PM   #22
bus-bro's Avatar
Engine: 3208 na boat anchor
Has anybody thought about getting some of those hefty magnets from Harbor Freight, and using those to hold a tarp on the bus. In a big wind the magnets might lift, but I'll bet they won't get far from the bus.
Old 03-02-2013, 07:09 AM   #23
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
I have visions of the wind catching that awning just right and sending those magnets sailing off and landing somewhere unpleasant.
Old 03-02-2013, 09:52 AM   #24
Rated Cap: 89
From page 1.....
Originally Posted by lornaschinske
Am I the only one who finds it amazing that people will use concrete blocks or little (or big) buckets filled with concrete to tie down their RV mounted awnings? David & I used to walk around the State Park we stayed in after a good storm.... to look at the damage the "tie outs" did to the RVs. My fav was the one that had the awning neatly wrapped up over the roof all the way around to the ground on the other side. The two concrete blocks had put a nice neat concrete block sized hole in the windshield in the front. And a nice hole right thru the siding towards the rear. You could see right into the RV thru the hole.
I don't think the huge magnets would be a whole lot different than the concrete buckets/blocks. I would rather lose a cheap awning than pay to fix someone's RV. I worried about the DollarTree screw-in-the-ground dog tie outs we used flying off during a wind storm and putting a hole in an RV or someone.
Fulltime since 2006
Old 03-15-2013, 11:48 AM   #25
Chassis: Genesis
Engine: Cornbinder 466
Rated Cap: 71
If you get one used make sure that you get measurements where all of the mounts go on the RV if possible. It will make your installation much easier. I put a used one on our bus and had to fabricate the lower mounts to make it fit. They are great to have and make sure that you get the small safety belts that secure it for the road.
The other thing that takes some thought is the cutting edge at the top of your door as it hits the angle of the awning. This is all set by how high you mount the grip strip on the side of your rig. If you are into fabrication check out Hannibal awnings. I was thinking of doing something like this but found a used unit on craigslist.
Tracy
Newfiedogs is offline   Reply With Quote
Old 03-15-2013, 02:56 PM   #26
bapos's Avatar
Question and maybe this should be tied to the other thread aboutthen square awnings thread but ill ask here...
When those of you who have put awnings on your bus where are they breaking? What parts are weak. Reason why I ask I dont mind making a redneck non pretty version of an awning but want to make sure i put money in the right places. I dont mind if it looks like a medevil torture device or not if it works and lasts. If it takes 45 minutes to put up so be it? any thoughts or suggestions would be appreciated.
Here is my school bus conversion thread http://www.skoolie.net/forum/viewtopic.php?f=9&t=10282
Pics of my conversion @ photobucket http://s18.photobucket.com/albums/b1.../School%20Bus/
Old 03-15-2013, 04:04 PM   #27
Chassis: Genesis
Rated Cap: 71
No matter what, it should be easy to set up and even faster to stumble out of your rig and take down when a storm hits.
Tracy
Old 03-15-2013, 05:47 PM   #28
bapos's Avatar
Thats true but they way I build most things metal most of us will be dust by the time they rust out if I have any say in it. My back yard smoker.... well the fire box alone is close to 450 lbs. So yeah I get a little carried away.
No plans or anything just started welding things together
Old 03-15-2013, 08:04 PM   #29
Chassis: Genesis
Rated Cap: 71
Nice smoker,
Nothing wrong with overbuilding, it's just another way of saying custom built to designer specs.
Tracy
installing awnings gbstewart Conversion General Discussions 9 05-18-2012 01:52 PM
Awnings Papabear Conversion General Discussions 11 08-25-2009 10:02 AM
Party Buses (In Buses In The News) lapeer20m Everything Else | General Skoolie Discussions 4 07-03-2008 02:43 PM
Buses buses, ya wanna know about buses ??? frank-id Everything Else | General Skoolie Discussions 0 10-19-2006 11:42 PM
Crown ??? Crown buses??? The best of all the school buses frank-id Conversion General Discussions 1 03-05-2006 03:30 PM
