Old 05-27-2017, 11:52 AM   #1
B700/Thomas Headlight fuse location.
I am looking for the fuse. I have a headache from looking under my dash.
Any ideas.
Old 05-27-2017, 11:57 AM   #2
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
On my C60 bluebird the head lights are fed through the dash switch then the floor dimmer. Breaker was in the dash switch.
Tootalltechie is offline   Reply With Quote
Old 05-27-2017, 12:55 PM   #3
Robin97396's Avatar
On my bus the fuse panel is under the panel on the back of the guage cluster. I'm guessing the fuse panel wasn't placed under the dash because of possible child tampering.
I wouldn't have found the fuse panel if I hadn't been looking for a mouse in the dashboard.
Robin
Nobody's Business
Old 05-27-2017, 01:22 PM   #4
Year: 1974
Rated Cap: 48
I have read somewhere that right and left are separate fuses. Hope this helps
Old 05-27-2017, 01:30 PM   #5
Thanks guys. I found a fuse box just like a Ford truck would have in the same area. Someone got black overspray on it when they did the dash. Can't read some of it and fuses are black and cannot read the amps. I think i will replace each one individually and wipe the paint off each fuse with Mineral Spirits.
I doubt it would hurt to replace 20 yr old fuses anyway.
