Old 04-12-2012, 11:13 PM   #1
roach711's Avatar
Rated Cap: 19
Backup beeper - keep it or trash it?
I can see how the backup beeper might be a safety feature but I also imagine it would be very unpopular when backing into a campground at midnight. Have you kept yours or disabled it?
The Roach Motel
Old 04-13-2012, 12:18 AM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Backup beeper - keep it or trash it?
Good question. Mine is still beeping away, but I've thought about pulling the plug on it many times. I'll probably end up disabling it.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 04-13-2012, 08:29 AM   #3
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
I think I might run a switch in line with mine to silence it when I need stealth, but keep it for the rest of the time.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 04-13-2012, 08:29 AM   #4
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
I would probably keep it. Not sure how other states do it but I can see them requiring it for some kind of safety inspection. With that said why not just put a toggle switch on it to turn it off. I can see it being a very good thing when backing up.
I dont really like mine but its more for other people to get the hell out of the way than to help me.
Bapos
Old 04-13-2012, 08:40 AM   #5
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
one of the first things i did was climb under the back and chop the positive wire. i mainly did it to try to annoy the neighbors a little less as i work on it. before i am finished i plan oon putting a toggle switch underneath right next to it. it wont be easy to get to, but i dont plan on keeping it on much, just able to for inspection or if we pull into a really crowded lot for something i can get out and turn it on.
hordechick is offline   Reply With Quote
Old 04-13-2012, 10:27 AM   #6
roach711's Avatar
Rated Cap: 19
Thinkin' I'll go with this approach. Now, where to put that switch?
The Roach Motel
Old 04-13-2012, 10:40 AM   #7
i am not disconnecting mine... but i also have traffic cones and a light bar for my business...
Old 04-13-2012, 12:39 PM   #8
syke's Avatar
Chassis: All American RE
We trashed ours. No real valid reasoning, just did not feel the need for it. Maybe down the road when I want a little side project I'll hook it back up with a toggle.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 04-13-2012, 12:55 PM   #9
I'd just use one of the tons of locations in my switchboard. I'm already kind of planning (long range anyway) to add switches for turning on a couple inverters, docking lights, battery disconnect, etc. to that panel.
-Dan
adjective
Old 04-13-2012, 06:58 PM   #10
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
send it my way ill use it
keith is offline   Reply With Quote
Old 04-14-2012, 08:36 AM   #11
TygerCub's Avatar
Engine: Detroit
I'm keeping my beeper. I can barely see the rear end and I'd rather have people hear the annoying beeper and stay out of my way than hope they see me backing up.
A toggle switch does sound awesome, though! Because the beeper is... well... very annoying.
Old 04-14-2012, 11:25 AM   #12
im thinking of adding a klaxton horn in line with the beeper...
Old 11-04-2015, 02:11 PM   #13
Chassis: International 3800 AmTran (wish it was a TransAm)
How do you find the back-up alarm wire? What do I look for? What would it be connected to?
AlbatrossCafe is offline   Reply With Quote
Old 11-04-2015, 03:30 PM   #14
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Turn your key on without starting the bus. Make sure parking brake is on and wheels are blocked. Put bus into reverse. Walk to the back of the bus with wire cutters and find the beeper and cut the wire. Put on butt connectors if you plan to hook it back up in the future.
I'm hungry!
You Gotta Let Me Fly
Reverse light and beeper. billofhouma Everything Else | General Skoolie Discussions 8 12-25-2010 10:37 AM
sunsetter awning in trash.. adamanderr Conversion General Discussions 1 11-21-2010 06:12 PM
Backup Camera? hoser Conversion General Discussions 4 10-25-2009 06:10 AM
Backup 12v Air Compressor 1964_Superior_Skoolie Conversion General Discussions 14 12-21-2006 10:58 PM
Cheap Backup Camera Steve Conversion General Discussions 16 04-07-2005 08:46 AM
