03-17-2016, 10:56 PM
I'm still backing over trees and stuff, but then I'm in Oregon.
03-17-2016, 10:58 PM
Engine: Cat 3126e
Rated Cap: 28
03-17-2016, 11:18 PM
I'm thinking a backup camera is probably a pretty good idea before I destroy anything belonging to someone else. So far I've just backed into my things.
Obviously RV's mount their camera up high, while some like the camera mounted near the hitch obviously for backing up to trailers. I've never had a back up camera but they aren't all that expensive depending on how far you want to go.
I would go with the cctv system as I believe the wireless models would encounter interference at least at times. I should probably make a choice on this subject myself since I do seem to be actively driving my bus. I try to avoid backing up, but someone will block you in even when you park at the far end of the parking lot.
03-18-2016, 06:46 AM
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
03-18-2016, 08:23 AM
i have a garmin/backup camera.
garmin rv760lmt
not cheap but real handy...
turf
here is an old thread on the topic:
http://www.skoolie.net/forums/f13/ba...-it-11446.html
03-18-2016, 11:10 AM
i love using the garmin. my biggest fear is theft. so it gets put away and stored inside when the bus is parked.
i wired the camera to the running lights, so its my rearview mirror as long as those lights are on, not just when in reverse.
a 7" screen is minimum..... bigger is better in a bus.
03-18-2016, 12:04 PM
Engine: Cat 3126e
Rated Cap: 28
Cool thanks Turf!
Ya I am totally undecided on what I want do. Just got to do lots of research. But I like that Garmin unit.
03-18-2016, 01:01 PM
Keep in mind that the Nanny Cams and Security cams were never engineered to go mobile, be shaken and vibrated. Heard from a couple of folks who used similar "stationary" units only to have them fail very quickly.
03-18-2016, 01:08 PM
Engine: Cat 3126e
Rated Cap: 28
Ya if I end up going that route going to have to figure out a solution to reduce vibration. Prop some type of base plate attached with silicone to the bus then another layer as well between the camera and base plate. But idno....decisions.. decisions....
Luckily my governor is set @ 52mph and I may only get it changed to like 60mph. Plan on traveling slow as we won't have any where to be.
03-18-2016, 02:23 PM
Duct tape!!!
03-18-2016, 04:58 PM
Coachwork: Crown / Pusher
I'm looking at a system that not only is used as a backup camera but can have 4 cameras at once on one screen & can record all 4 on a 8 hr loop
03-18-2016, 05:22 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Back-up camera? PUHLEASE! Thats why I have 6 outside mirrors and one inside mirror. Besides, if I can back a 53' trailer from the inside of a 26.5' tractor without a back-up camera, a 40' bus is a lead pipe cinch.
03-18-2016, 07:55 PM
Rated Cap: 2+1
I'm with you on this one,started n 40fters and they just kept getting bigger
With no extra training so after almost 40 years total..I may just get lazy and get me one of those back up cameras.
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
03-18-2016, 09:18 PM
I have a back up camera, 7inch color screen, I ran the wire inside the bus , the camera is mounted inside pointing out the back window , I have it wired so I can turn it on and watch my scooter if I have it on the back of the bus. I"m going to move the camera and mount it on top of my A/C.
03-18-2016, 09:20 PM
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
Our 2 camera system was a cheap ebay setup for like $50. The idea was to put them both on the top of the back of the bus, one pointing down at the bumper (our bumper is a 3 ft deck) and one pointing out straight at traffic. Turns out they pretty much do the exact same view, and the cheaper tinier camera was better quality than the other nightvision capable camera, so we just use the one. It gives us a view of the deck and generator and bikes as well as behind the bus and most of the blind spot. Eventually I'll disable the useless other camera and put one on each side of the bus near the driver area facing back down the sides. It really helps for switching lanes and also has the lines on the screen so we can back up within inches of something. It has been one of the best things we've done for ourselves.
My build thread:https://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
03-19-2016, 09:41 AM
Engine: Cat 3126e
Rated Cap: 28
That is what I am going for as well. Looking for more of a security system that could double as a back up camera hopefully as well.
03-19-2016, 10:04 AM
Chassis: thomas
Engine: 8.3 cummins
the nanny cams are made to be placed wherever the kid is so i m o they would hold up to abuse more than a security cam , at least the name brand ones. you get what you pay for. when you need it just set it in the back window and put away when not in use.
03-19-2016, 11:23 AM
Location: Henley-on-Thames, United Kingdom of Great Britain and Northern Ireland
Rated Cap: 29
My Build site is https://schoolbusconversion.net
