Old 10-14-2006, 08:26 PM   #11
If you are coming through Idaho email me and I can take a look at it. I am close to Twin Falls about 2 miles from I-84.
busone is offline   Reply With Quote
Old 10-15-2006, 06:26 PM   #12
My bus had the exact problem. The rear heater was removed and the lines were plugged. The front heaters did not work. I reinstalled the rear heater and then all of the heaters worked. I then realized that all the heaters were on a single loop. By plugging the lines to the rear heater, this stopped flow to all of them. If you don't want to use the rear heater, replace it with a hose coupling.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 11-18-2006, 03:49 PM   #13
same..if you come by Sterling Colorado I'd be happy to have a look at it.... nice song and the myspace BTW
Demonknight is offline   Reply With Quote
freezing yet? GetTheFunky1 Conversion General Discussions 22 02-24-2014 09:03 AM
new 1987 thomas built conversion for band tour bus bansil Short-Bus Conversion Projects 6 08-02-2012 05:30 AM
Its freezing temps, motor ok? Jaybus Ford Drivetrain 3 10-26-2011 11:40 AM
Making a band tour bus: is it a good idea? Jarlaxle Conversion General Discussions 8 02-23-2010 11:11 PM
Rock Band Tour Bus? jgevans Conversion General Discussions 13 03-14-2007 09:49 AM
