Old 02-03-2019, 02:58 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Barring a dt466e
Any tricks on barring this thing over? I've got all the pistons that are in the up, but need to turn over the crank. My cummins 5.9 had a gear you could insert and crank it over with a socket wrench.
Dead pirate is offline   Reply With Quote
Old 02-03-2019, 05:24 PM   #2
Chassis: Ford B700
Engine: 5.9, Spicer-5
Rated Cap: 44 Big butts/66 Lil ones
Any way you can get a socket on the harmonic balancer center bolt? Or a strap wrench or chain-wrench around the harmonic balancer, itself.
one_eyed_jack is offline   Reply With Quote
Old 02-03-2019, 08:41 PM   #3
Coachwork: myself
Chassis: amtran
No socket but maybe a strap wrench. Thanks. I'll look at that. I was also thinking about the u-joint as a possible rotation point. Its in neutral and should move easily enough. I don't know.....
Old 02-04-2019, 07:21 AM   #4
on my DT 360 when i did the trans swap I had to crawl under and use a big screwdriver in the flywheel teeth a couple teeth at a time to turn it over... the inspection hole in the bottom of the housing was a great leverage point for the screwdriver and with a big blade you wont trash the flywheel.
Old 02-04-2019, 07:41 AM   #5
Chassis: International 1753
Engine: 6.9 International
Do this. The dt466 uses multiple small bolts vs one large one to hold the balancer on. I've seen people snap those small bolts barring it over. I've also seen an engine self start by barring it over with a breaker bar. It's a lot less dangerous for you and the machine doing it a few teeth at a time off the flywheel.
