Old 04-28-2018, 05:55 PM   #1
Chassis: E-450
Engine: 7.3 Turbo
Battery Storage
I can't quite figure out the best way to approach a battery compartment for a couple of house batteries. We'll likely have 2 max and our plan is for cheapo lead acid ones considering our planned usage (fan, pump, charging).
The two options are under the bus and inside vented. I have questions for both.
If the compartment is inside, does the vent need to have a fan or is a regular vent good enough? How sealed does it need to be?
I'd prefer to mount it underneath though, mainly because we have a ton of space. I've been looking through how other people have done theirs, but I can't find a prebuilt box that fits nice. I don't have the tools to make a custom box, and would rather not pay.
Is it possible to do it w/ marine grade plywood? If it's underneath the bus, do they need to be enclosed or could I just do a platform?
Suggestions or links to good build threads w/ this type of work are both appreciated.
Our build thread
PigPen is offline   Reply With Quote
Old 04-29-2018, 11:44 PM   #2
Jdawgsfanasty's Avatar
Building a wooden box could work...do you have access to a truck salvage yard? Might find a sweet box on the cheap...
Jdawgsfanasty is offline   Reply With Quote
Old 04-29-2018, 11:54 PM   #3
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
I made pull-out drawers under the bus for the start and house batteries, but they're open to the road below. This, along with some ventilation louvers for the house batteries, ensures good ventilation, and if anything leaks or spills it will just drip harmlessly to the ground.
Old 04-29-2018, 11:59 PM   #4
Look for some plastic storage bins at Wally world or local discount stores. Cheap, will contain any leak, and can easily be cut to desired height.
Dave in Tucson is offline   Reply With Quote
Old 04-30-2018, 07:27 AM   #5
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Look for some cheap STOUT plastic storage bins... and be sure they're properly supported.
Dapplecreek is offline   Reply With Quote
Old 04-30-2018, 07:53 AM   #6
you could also go to a junkyard and cut the battery box off of another bus.. on my bus the battery box appears to just be spot-welded to the body ribs and skirt.. drill out the spot welds and it would be outta there.. could be bolted or welded to anbother bus..
Old 04-30-2018, 09:44 AM   #7
Just for the record...
Old 04-30-2018, 09:56 AM   #8
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Does anyone know any specific builds that documented their battery mounting and building battery box? Trying to figure out how to secure everything underneath and I'm a visual kind of guy so pictures help a lot
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 05-01-2018, 11:39 AM   #9
Da good stuff!
Are you an A&P? You know too much.
Old 05-01-2018, 11:47 AM   #10
IWC Bus's Avatar
Chassis: A3RE
Engine: 3126 Cat
Rated Cap: 33220 GVwR
You can try Dlzfreek on YouTube there is a video when he rebuilds his battery box.
The Rev.
Don't Fret God's Not Through With Me Yet!
IWC Bus is offline   Reply With Quote
Old 05-01-2018, 12:45 PM   #11
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
I worked a metal coating plant that did vehicles for the military all their trucks get a similar coating in their battery boxes, it's fantastic stuff
Whatthefak is offline   Reply With Quote
batteries, battery storage, storage
