Old 11-14-2019, 06:47 PM   #1
Chassis: TC1000 FE
Engine: 5.9
BB TC1000 roof raise tubing size
IMG_20191114_103341.jpgSo I've tried 1 1/4" tubing at both 14 and 16 gauge and they're both too big to get flush with the back of the rib even with two clamps trying to get it back in there. 1" is too small. I think it gets narrower the further back in it goes. Do I need to get some 1 1/8" or is it ok that the tubing doesn't sit completely flush?
lebusmagique is offline   Reply With Quote
Old 11-14-2019, 06:54 PM   #2
Interesting....
I used a 1-3/8' wide C channel and I fit perfectly..
The square tube I have used on other projects has always been measured on the outside dimension.. Changing the wall thickness will not change the outside dimension.
Old 11-14-2019, 07:01 PM   #3
Chassis: TC1000 FE
Engine: 5.9
Good to know. Makes sense. Not sure why I didn't realize that. I'm kinda stumped though. I wanted to figure out what size to use before I make an order at the local steel mill but 1 1/8" doesn't seem to be something you can get anywhere unless you order it.
Old 11-14-2019, 07:05 PM   #4
I measured mine with digital calipers and had C channel bent up from 1/8" flat stock.
It fit perfectly and is s heavier than the hat channel.
Old 11-14-2019, 09:02 PM   #5
That's why I had some custom channel made. I wanted it to be perfect.
Roll Your Own Build Thread
Old 11-14-2019, 09:49 PM   #6
Chassis: TC1000 FE
Engine: 5.9
Well luckily I know the former CEO of the local steel mill and I just contacted him and he told me they can make custom hat channel no problem. Would the easiest thing be to just cut a section and bring it up there?
Old 11-15-2019, 02:21 AM   #7
I cut a section out of a rib and took it to the fabrication shop my step dad works for.
Old 11-15-2019, 03:26 AM   #8
Having a sample always helps the fit.
Old 11-15-2019, 10:49 AM   #9
Chassis: TC1000 FE
Engine: 5.9
Cool. Do I get it made to fit on the outside or inside of the existing channel? I assume the process is the same as using square tube? Just get them made up so that there's about 6" of overlap on each side? Where exactly did you make your welds?
Old 11-15-2019, 10:52 AM   #10
Chassis: TC1000 FE
Engine: 5.9
And do you also need "C" channel to go on the inside for reinforcement or no?
Old 11-15-2019, 12:11 PM   #11
The "C" channel goes inside the hat channel. I have hat and "C" channel available.
o1marc is online now   Reply With Quote
Old 11-15-2019, 01:31 PM   #12
The channel goes inside the existing bus rib. Can use thin angle iron or have some 18ga angle bent up when you have the channel made. Use that to attach the skins. SHouldn't cost more than a couple hundred bucks.
Old 11-15-2019, 01:32 PM   #13
Have you checked that it will work on BB?
Old 11-15-2019, 01:44 PM   #14
Not yet, question was asked about measurements, it was ignored.
Old 11-15-2019, 02:04 PM   #15
Check MuddaEarth he did his on a BB. IIRC 1 1/4" sq tubing fit like a glove but I'm not 100% sure on the size.
Old 11-15-2019, 07:15 PM   #16
Chassis: TC1000 FE
Engine: 5.9
I'm getting there. Left my old calipers out in the rain
Old 11-15-2019, 07:17 PM   #17
Chassis: TC1000 FE
Engine: 5.9
Ok I understand. Let's say I do a 14" raise. I'd get 24" of hat channel to have 5" of overlap on each side. Does the C channel need to be 28" or so?
Old 11-15-2019, 08:55 PM   #18
If doing a 14" raise you need 14" Hat channel and 24" "C" channel.
Old 11-16-2019, 05:27 AM   #19
I did a ten inch raise and I used something like 30" c channel. Measure and make it long as you can the more overlap the better.
Old 11-16-2019, 10:41 AM   #20
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
I did a 24” raise and I just took a chunk of the OE hat channel to a local fabrication shop and got him to custom make 48” hat channel to fit over the existing channel. This put the fabricated channel in the inside which kept the new channel from interfering with installing the exterior sheathing. Cost me $420.
I used farm jacks to raise and tek screws held it all in place for the 10 mile drive to the welder.
Skipoffools is offline   Reply With Quote
