Old 02-06-2007, 06:34 PM   #1
Send a message via Yahoo to crispyx
Belt driven Generators
Does anyone have experience with these? Since our conversion is more for touring and being comfortable on long drives I'm thinking about going with a generator in the engine to run appliances and computers while on the road. I expect once at our destination if we're staying in the bus we'll be looking for campgrounds where we can plug in.
crispyx is offline   Reply With Quote
Old 02-06-2007, 06:37 PM   #2
Steve's Avatar
I always wanted to get an AuraGen but they have to be installed and programmed by the manufacturer and they are pretty expensive.
http://www.aurasystems.com/pages/AuraGe ... enHome.htm
Old 02-06-2007, 06:52 PM   #3
I was looking at this one http://www.raventechpower.com but the Auragen looks pretty nice too.
Old 02-06-2007, 09:17 PM   #4
the_experience03's Avatar
I don't see a price, but it looks interesting. They talk about running it off a PTO, but then they say it's mounted underhood on that Ford so I don't know which way it operates. Belt driven would obviously be better for the bus application as I have yet to see a bus with a power take off though the Allison's do have the provisions for them. With that gennie, a 3:1 ratio would be ideal I think. You'd have to go over 3333 RPMs to overspeed it while a 1000 rpm high idle would give you the 3000 rpm at the gennie required.
Northern Tool sells a similar output gennie head that might work in the same application for $400 http://www.northerntool.com/webapp/w...6970_9040_9040
I don't see any minimum or maximum speeds listed though which could come into play. It also wouldn't include a clutch to disengage it. While an AC compressor type pulley clutch would work great on it, I'm not sure how well you could adapt it to this use. It is worth looking into though given the price. Perhaps a call to Northern could answer the questions as to feasibility of one of those gennie heads under hood.
Old 10-29-2007, 07:48 AM   #5
Buster's Avatar
Year: 1974
Chassis: Ford B-700
Engine: 351 windsor
Re: Belt driven Generators
the frequency at rpm is determined by the number of poles in a generator. (alternator) a 3600 rpm generator has 2 poles an 1800 rpm generator has 4 poles etc. A generator, at the leads makes dc, an alternator at the leads makes ac. That's why you need diodes in the circuit with your alternator to charge your start battery. I would think that if the rpm is not going to be constant dc inverted to ac would be the way to go. Just my opinion though.
Dave
Buster is offline   Reply With Quote
Old 10-29-2007, 09:30 AM   #6
Buster's Avatar
Year: 1974
Chassis: Ford B-700
Engine: 351 windsor
What the heck was I thinkin', I have a 5kw coleman welded to my back bumper. It runs great while toolin' down the road. But then again that's something else to pour fuel into.
Just thinkin' out loud.
Dave
Engine driven Compressed air for skoolies without air brakes nat_ster Conversion Tutorials and How-to's 34 09-10-2019 09:10 AM
DT466e belt tensioner fail rv8flyboy International | Navistar Drivetrain 2 06-30-2014 08:02 PM
Tensioner Belt Comes Off Radiator Fly Wheel on MCI-9 bus-bro Detroit Diesel Drivetrain 1 08-04-2011 03:18 AM
anyone know about propane driven buses? luckyone Everything Else | General Skoolie Discussions 4 07-31-2011 02:15 PM
How to loosen a serpantine belt Dain Mechanical and Drivetrains 4 05-20-2011 03:15 PM
