Old 09-26-2016, 09:05 AM   #1
Chassis: B600, 545 Allison Auto
Engine: Cummings Dimple Block 12Cyl.
Rated Cap: 70
Best Floor paint
Hi Guys
My conversion is going well so far.
I have the seats out and floor up.
I have been searching the forums for the best type of (cheap) floor paint to seal before I insulate. (no luck)
Does anyone have any good recommendations?
Thank you
Howard
HJS26 is offline   Reply With Quote
Old 09-27-2016, 02:20 PM   #2
Coachwork: AmTrans
I used POR 15 along with their Metal Prep. Worked awesome. Its more expensive but worth it. But you could prob just use Rustoleum paint and primer if you really need to save the money. But for the exra 50 or 60 bucks I would highly recommend the POR 15. Especially if there is any surface rust already present.
WhiteWhale is offline   Reply With Quote
Old 09-27-2016, 02:54 PM   #3
NowhereFast's Avatar
Chassis: Carpenter
Engine: d466 mechanical
Any Home Depot will have some rustoleum which will work good enough.
If you had surface rust make sure you removed it and treated it.
Any holes from the seats fill and seal. And if you had any bigger holes make sure to patch those. You'll be good to go
Nowhere Fast - Sarasota, Florida
NowhereFast is offline   Reply With Quote
floor, paint
