Old 06-16-2018, 09:57 PM   #21
Engine: dt466e
Originally Posted by Rovobay View Post
my signature below!
Signature?
adic27 is offline   Reply With Quote
Old 06-17-2018, 12:31 AM   #22
Rovobay's Avatar
Rated Cap: 35
Originally Posted by adic27 View Post
Signature?
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
the last line in the post I made.
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 06-18-2018, 07:21 AM   #23
Chassis: Amtran
Hi ,
I put mine in the front hole where the original vent was as it was leaking as you indicated and I have a window in the back I open so it pulls air from back to front and helps a lot. Definitely one of my better decisions
Cdimples67 is offline   Reply With Quote
Old 06-18-2018, 11:49 AM   #24
Chassis: TC 2000
Rated Cap: 65?
I put mine in the front. just behind the hatch. Theory was the heat off the engine (FE) would go up and out and cool air in from the door or window. It works well, two would be better but I am waiting on a rooftop ac for the back half of the bus. I also have an O2 cool USB fan directly on me when working on the back half (not done converting). The air isn't moving back there as much.
Stuntmanmitch is offline   Reply With Quote
Old 06-18-2018, 04:48 PM   #25
Engine: 466e
Rated Cap: its Yuge
Thanks for all the great comments. My plan is to to this for now, then adjust with more air flow if needed
MambaJack is offline   Reply With Quote
Old 06-18-2018, 04:52 PM   #26
Engine: 466e
Rated Cap: its Yuge
Originally Posted by superken View Post
I have tried to replace my roof vents twice and regretted it both times. Plus they are too wide so you have to fab a smaller hole. It is easy to put a fresh metal cutting blade on a circular saw and cut through both the roof and ceiling at the same time (careful, it’s also easy to cut through the structural beams). I use my roof hatches a LOT more than I thought I would especially after I put a Jeggs rooftop cargo carrier, but also to repair solar or install a telescopic ladder to easily get up to your deck.
What did you try to replace them with?
The comment about easy access to the roof is really making me reconsider. I love the sunroof idea but worry it being in accessible
Old 06-19-2018, 07:49 PM   #27
thrifty1's Avatar
Engine: DTA360
A ladder will give you access to the roof. Ventilation is priceless.
thrifty1 is offline   Reply With Quote
